Buying Wheels Need Help
Old Oct 12, 2006 | 02:54 PM
Kabs's Avatar
Kabs
Default Buying Wheels Need Help
I am planning on buying wheels.
Wheel Diameter (Inches):
18"
Wheel Width (Inches):
8.5"
PCD Bolt Pattern:
5x114.3
Offset:
25mm
Hub Bore:
67.1
18"
9.5"
PCD Bolt Pattern:
5x114.3
Offset:
28mm
Hub Bore:
67.1
And I need help choosing a tire size. I was recommended to go 255/35/18 and 275/35/18. Is this a wise choice? I want fat tires but nothing like 295+ . Also is the 35 good? or should it be 40?
I would like this to be a fairly safe setup =P With no rubbing. Does the 2nd number basically determine how fat the tire is from the lip to the top?
Thank for your help.
Old Oct 12, 2006 | 04:36 PM
Kabs's Avatar
Kabs
anyone?
Old Oct 12, 2006 | 05:21 PM
The sizes that you have selected are the same as the NISMO wheels. Use the NISMO recommended tire sizes.
Old Oct 12, 2006 | 06:25 PM
plumpzz's Avatar
plumpzz
I think you were suggested 245/40 275/35 or 265/35 275/35 For the 'look good' kinda look. For handling and stability i'd do 265/40 all around.
Old Oct 12, 2006 | 07:40 PM
Kabs's Avatar
Kabs
raj get online
Im not doing 9.5 all around im doing 8.5F 9.5R.... so I need to know should I do 35 or 40
I want the looks good... and if look good is safe then ill stick to it
Old Oct 13, 2006 | 07:43 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
245/40/18 front (or a 255 if you can find them) 275/40/18 rear
a 265 on a 8.5 inch wheel looks ridiculous (IMHO)
Old Oct 14, 2006 | 07:46 PM
Kabs's Avatar
Kabs
can anyone tell me what the difference will be between a 35 and a 40
Will my tires be more low profile? Will the 35 be unsafe?
Old Oct 14, 2006 | 08:05 PM
Z1 Performance
Former Sponsor
read above...we suggested the right info already
Obadabot
Jun 18, 2023 11:31 PM
