Adjustable Pillow Balls (can someone explain)
Old Mar 13, 2003 | 03:28 AM
wadd3456's Avatar
wadd3456
Default Adjustable Pillow ***** (can someone explain)
Can anyone explain exactly what an adjustable pillow ball does and HOW it does it. Also, do you have any close up pictures of this part.
THis sounds like a stupid question, but I am leading up to something.
Thanks
Old Mar 23, 2003 | 06:19 PM
Boomer's Avatar
Boomer
Default Re: Adjustable Pillow ***** (can someone explain)
Thanks
I don't think its a stupid question. I would like to know what they are and what advantage do they give you over conventional parts? A pic would be helpful, too. I have never heard of them before I started reading about coilovers.
Old Mar 26, 2003 | 10:38 PM
krinkov's Avatar
krinkov
Im not sure where the term "pillow ball" started(never heard of it in any shop I ever worked at ) but its basically a replacement upper strut mount that uses a spherical bearing to loacte the top of the strut instead of the typical rubber bushing. On a macpherson strut type suspension where the strut also acts as the upper control arm, any flex in this rubber bushing also incures a subtle alignment change, so taking the flex out of this bushing would reduce that. Also, since the location of strut in a macpherson suspension also affects camber/caster, an adjustment for these settings is usually included on these pillow ball mounts(as pictured)
As for the Z, with multilink suspension, niether the placement of the strut mount nor flex in its bushing has any affect on alignment. If they already come with a kit you are buying fine, but not worth it to get on their ownIMHO.
Old Mar 26, 2003 | 10:39 PM
krinkov's Avatar
krinkov
oops! heres that pic
Attached Thumbnails Adjustable Pillow Balls (can someone explain)-hks-pillow-ball003.jpg
Old Mar 27, 2003 | 03:24 AM
wadd3456's Avatar
wadd3456
Hmmm weird. I so that wouldnt even work to adjust ours. I would reaaaaaaaaaaaaaaaaaaaly like to see pictures of the setup AVALON racing has.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
