offset for veilside v3 wide
Old Oct 23, 2006 | 02:42 AM
jeff_chen0209's Avatar
jeff_chen0209
Default offset for veilside v3 wide
im just wondering wut offset should i get for the front and rear.....
is 19" ok wif it ?? or 20 is a must for the gap to be minimal??
i found that recommended size is..20 x 9.0J(+18mm)f..20 x 11.0J (-18mm)r....... so wut if i hav 19*9.0 (+18mm)f.. 19 x 11.0 (-18mm)r...?? will it be alot diff. between 19" and 20"??? .....
also wondering about the tire sizes ....plz help ..... thx.........
Old Oct 23, 2006 | 10:14 AM
Touring240's Avatar
Touring240
I highly recommend fitting the body kit and setting the stance first. Then start measuring using the wheels you have on the car already to determine the widths and offsets that best suit your needs.
You may find you can go more aggressive depending on your alignment settings.
Old Oct 24, 2006 | 04:57 PM
GBCUSTOMS's Avatar
GBCUSTOMS
I'm needing the same question answered. What offset for the veilside kit?
Where did you find the info on the recommended offsets?
Daewoo
Dec 13, 2013 09:25 PM
blue06z
Aug 9, 2006 08:45 AM
johnwko
Jun 24, 2006 11:37 AM
johnwko
Jun 21, 2006 04:19 AM
thackattk
Sep 4, 2003 10:25 AM
