Te37
Old Oct 27, 2006 | 02:49 AM
alexml's Avatar
alexml
Default Te37
my next mod has to be on the wheels, and the TE37 is taking my preferences
my question is: "if someone knows!"
What is the best tire size on the Front TE37 in 19x9.5+22 Rear 19x10.5+22
having in mind that i do not whant to compromise the performances because i only have an intake air kit from KN
any one ?????
Old Oct 27, 2006 | 04:09 AM
DavesZ#3's Avatar
DavesZ#3
The "standard" upgrade size would be 245/35/19 up front and 275/35/19 out back. You can go larger but that only increases the weight and rolling resistance which in turn, hurts performance. The good news is that the TE37s are lightweight so that helps offset some of the loss.
Old Oct 27, 2006 | 02:15 PM
bb200bmw's Avatar
bb200bmw
why do you need 10 inch wide rims?
Old Oct 27, 2006 | 02:18 PM
sokudo9l6's Avatar
sokudo9l6
so that they'll be flush and not tucked inside the fender wells.
Old Oct 27, 2006 | 04:17 PM
Zreign's Avatar
Zreign
10 in? try 10.5in
Old Oct 27, 2006 | 04:40 PM
Nitrouz's Avatar
Nitrouz
Back to Z
so we can run wide tires.
Old Oct 27, 2006 | 04:46 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Becuase 275 tires are a joke and you need something wide like 10.5 to slam some 305 to keep the power down.
Old Oct 28, 2006 | 12:16 PM
NISMOFO's Avatar
NISMOFO
I'm running 255/35 & 275/35 on my LE37T's.......same sizes/offsets you mentioned.
Old Oct 28, 2006 | 12:25 PM
Ilov350ZEE's Avatar
Ilov350ZEE
wider is BETTER!
Old Oct 28, 2006 | 12:45 PM
Nexx's Avatar
Nexx
Originally Posted by Ilov350ZEE
wider is BETTER!
thats what she said!
Old Oct 28, 2006 | 01:23 PM
josephchihweilu's Avatar
josephchihweilu
+22 offset is good. if i were you id sacrifice a little bit and make it flush all the way. id do +17 front and +21 rear. 9.5 and 10.5 widths respectively of course.
Old Oct 28, 2006 | 02:39 PM
Motormouth's Avatar
Motormouth
I have 8.5 (255/35) and 10.5 (275/35) 19 in TE37.
if I did it again? 9.5 (265/35) 18in and 10.5 (285...295/35) 19in.
the front end looks too upright with a 19inch front.
Old Oct 28, 2006 | 11:30 PM
JDMZ-33's Avatar
JDMZ-33
I'm in with all the others 255/35 and 275/35 on S-03
Old Oct 29, 2006 | 10:27 AM
__jb's Avatar
__jb
Z + Rear Seat
I'm curious why some of you run a 255 on the front and only a 275 on the rear. It seems like it would be more balanced to run a 285 on the rear.
What am I missing?
Old Oct 29, 2006 | 01:18 PM
NISMOFO's Avatar
NISMOFO
What am I missing?
For me, I decided the 255/35 & 275/35 combo because I know the 245/35 looks WAY too stretched on a 19x9.5. I wanted as close to stock diameters as possible and the 275/35 is the way to go as far as keeping all of my gauges, etc as close to accurate as possible. But even moreso than anything else, with a +22 offset a 285/35 will rub and I am NOT about to roll or cut my fenders.
Lastly (for those of you who care oh so much about lightweight rims...and you do if you're buying TE37's or LE37T's), the 285/35 tire (at least in a Toyo) weighs about 3 lbs more per tire than a 275/35.
These are all of the reasons why I run the 255/275 combo.
Old Oct 29, 2006 | 01:20 PM
Reyes_USN's Avatar
Reyes_USN
bcoffee20
Nov 19, 2015 06:39 PM
davidm350
Oct 31, 2015 02:28 PM
fairladyZ in Japan
May 1, 2003 03:02 PM
zyu
Apr 13, 2003 09:08 AM
