tire pressure
Old Oct 4, 2006 | 09:17 PM
creationv2's Avatar
creationv2
Default tire pressure
heeeey all i have a problem i think.....ive been keeping track of my tire pressure this week and one of the rear tires is consantly around 8-10 psi lower than the other tire.....(idk which, whichever is the bottom tire pressure on the dash guage)...and i chk the pressure every morning and when i get home, so cool and heated, and the cool state its about the same....but when heated such as when driving....theres that gap again.....so should i add air? or go to the dealership? or wha?
Old Oct 5, 2006 | 03:47 AM
DavesZ#3's Avatar
DavesZ#3
Bottom is usually the left/drivers side.
Are you checking pressure with a gauge or just going by the reading on the TPMS?
Nail in tire?
Leak at bead?
Old Oct 5, 2006 | 07:51 AM
The tire has a slow leak.
Old Oct 29, 2006 | 01:38 PM
the2dwarf's Avatar
the2dwarf
Does anyone out there know how to defeat the TPMS ?
Am considering another set of wheels for the winter and plan to run them without the sensors and all the same size vs the staggeered size it calls for...
Old Oct 29, 2006 | 03:21 PM
DavesZ#3's Avatar
DavesZ#3
You're confusing TPMS and VDC. TPMS is the tire pressure monitoring. If you run wheels without the sensors, then the system won't display pressures. After driving on them for about 45 minutes, the warning will sound and the (!) light will stay on. It doesn't do anything but that.
If your car has TCS or VDC and you run non-staggered sizes, then that will trigger the TCS/VDC. You have to drive with the TCS/VDC off button pressed to keep it from kicking in.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
