helps....offset & rolling fender
Old Nov 5, 2006 | 11:43 AM
norapat01's Avatar
norapat01
Default helps....offset & rolling fender
Please help, i dunno know **** when it come to wheels. just got a quick question here guys.....I finally decided that i need a set of wheels. My Z is not lower, but i might go with Tein S-tech in the future which should lower the Z about 0.8 of an inch. The wheel that i look at is 18 x 8.5 in front and 18 x 9.5 in the back, both got 20 offset so...do i need to roll my fender to avoid the rubbing? And what size tire is the max width of the tire i could run if i want to keep the 40 profile ( xxx/40/18 )
Thanks a bunch
Old Nov 5, 2006 | 12:28 PM
norapat01's Avatar
norapat01
....anyone? I'm about to go crazy with all the different numbers and sizes
Old Nov 5, 2006 | 01:22 PM
plumpzz's Avatar
plumpzz
no you'll be fine.
Im running 18X9 +20 in the front and 18 X 10 +18 in the rear and i wont rub unless im lowered more than 1''. Moreso, it depends on your tire. If you run 245/265, you won't rub.
Im personally planning on running 255/265 in the future, or maybe even 265 all around.
Old Nov 5, 2006 | 04:23 PM
norapat01's Avatar
norapat01
Originally Posted by plumpzz
no you'll be fine.
thx, you da man
Old Nov 5, 2006 | 07:03 PM
Tires? The wheels that you selected are the same size as the NISMO wheels. Just go with the sizes recommended by NISMO.
Old Nov 5, 2006 | 09:29 PM
norapat01's Avatar
norapat01
really? I think nismo use stock size tires right? 225 up front and 245 in the rear?
Old Nov 5, 2006 | 09:57 PM
ppw350Zunit's Avatar
ppw350Zunit
that would look too stretched for nismo wheels....buy new tires: 245/40 and 275/40.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
