WORK S1 19" offset +12 and +2? possible?
Old Nov 15, 2006 | 06:37 PM
JDMZ-33's Avatar
JDMZ-33
Default WORK S1 19" offset +12 and +2? possible?
Hi Guys,
Just discuss with my WORK wheels dealer. Since my 350z its a Track model
( came with OEM brembo breaks ) It need spacer to make it fit, if i want super deep dish.Then, He gave me this option " 19 x 9.5 offset +12 and 10.5 offset +2" ( including spacer fitted in the wheels). will this offsets fit? if its sticking out a lil bit, it doesn't matter to me.
Opinions please from wheels expert
cheers,
Jerry
Old Nov 16, 2006 | 04:46 AM
djnc's Avatar
djnc
i'm no expert, but it sounds like you'll need some serious negative camber and stretched tires to have no rubbing
Old Nov 16, 2006 | 05:30 AM
taurran's Avatar
taurran
That or widebody fenders.
By the way, wheel spacers do not effect the size of the lip. What's the offset without the spacers?
Old Nov 16, 2006 | 05:50 AM
JDMFairlady21's Avatar
JDMFairlady21
ask them what type of disk are on the wheels (this affects caliper clearance), the spacers arent necessary most likely, post the real offsets and disk type and we can def help you out =)
Old Nov 16, 2006 | 08:27 AM
JDMZ-33's Avatar
JDMZ-33
Yupp, i know spacers do not effect the size if the lip, Just to clear the OEM brembo breaks and the original offset without spacers is
19x9.5 A disk +29
19x11 A disk +22
Old Nov 16, 2006 | 08:40 AM
JDMZ-33's Avatar
JDMZ-33
Guys,
As posted in the old thread 19x9.5 O disk +23 and 19x11 O disk +17 would only fit into non-brembo Z. If I want this kind of offsets it will need to be fitted with approx 10mm spacers,to clear the OEM brembo breaks.But somehow the WORK reps offering me
19x9.5 O disk +12
19x11 O disk +2
with spacers fitted on the wheels
He did said I have to modify my fenders and previously i did rolled up my fenders but not sure whether its flat enough to prevent any rubbing issues
Maybe I should just ask him to order 19x9.5 O disk +23 and 19x11 O disk +17 with spacers. That still more make sense to me. Instead of offsets +2 in the back
What do u guys think?
Old Nov 16, 2006 | 10:27 AM
Zexy's Avatar
Zexy
19x9.5 +12 in the front you could probably get away with a stretched tire. and 19x11 +2 offset will absolutely not fit ... Even with a streched tire your car will look like a California lowrider..
BTW: if you want O disks do not even think of running BBK.
Which work rep are you talking to? They're lying. Those are way too aggressive.
BTW2: O disk 19x11 +17 rears will fit rear brembos.. Anything bigger than stock in the front you will need another disk with smaller lip to clear.
Old Nov 16, 2006 | 11:07 AM
JDMZ-33's Avatar
JDMZ-33
Thx for the info,Zexy.
I'm discussing it Work wheel New zealand raps. Btw, here my tires size 245/25 front and 275/35 rear. Thats what on my mind before offset +2 its not possible, so i better make sure before i order the wheels.
OK, so O disk +17 will clear the oem brembo. How but the front? O disk +23 definelty will fit,right? +12 still not sure
Old Nov 16, 2006 | 11:39 AM
JDMZ-33's Avatar
JDMZ-33
OK, Here what I'm aiming for, Deeeep dish + I can see there brembo breaks in picture. so, what offset that style king 350Z running?
Old Nov 16, 2006 | 11:48 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Your best bet is to know which BBK u are probably going to end up with and pass the dimensions etc to your rep. However, based on what the REP that you are working with gave you...it looks like you may need to call someone else that probably knows more about this subject as he seems like he doesn't know what he is doing in regards this setup
Old Nov 16, 2006 | 11:58 PM
JDMZ-33's Avatar
JDMZ-33
Guys,
I posted the pics to the Works reps and he got the exact offset and size of the wheels in the pics
strangely, I remember read it some magazine the size of the wheels was 19x9.5 and 19x11 but the reps told me it was 19x9.5 and 19x10 surely with different offsets
Old Nov 17, 2006 | 02:27 PM
mich's Avatar
mich
this is just an educated guess, but i think the specs on the styleking z33 is,
19x9.5+12 R-disk
19x11+17 O-disk
Old Nov 17, 2006 | 02:50 PM
Zexy's Avatar
Zexy
If you have Brembo in the front you're gonna need a shallower disk to fit Brembo. I don't think O disk +23 9.5 in front will fit.
I had a shallower disk for BBK and clearance with Brembos was very minimal.
seagrasser
Oct 11, 2015 03:27 PM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
