Steering off-center...
Old Nov 22, 2006 | 08:41 AM
funkdamonkman's Avatar
funkdamonkman
Default Steering off-center...
On my way to Dallas I noticed that the steering wheel is about 5 degrees to the right when the car drives straight. The car doesn't drift, and the tire pressures are all the same.
Could there be anything else wrong besides a bad alignment? I had the car aligned about 1000 miles ago and it was fine then.
Old Nov 22, 2006 | 09:08 AM
DavesZ#3's Avatar
DavesZ#3
It might be aligned correctly but they didn't have the steering wheel centered when they did the alignment. Now, when the wheels point straight ahead, the steering wheel is not in the centered position.
Old Nov 22, 2006 | 10:24 AM
Agree. The steering wheel is aligned using the coupler in the linkage. A do-it-yourself fix takes a bit of trial and error.
Old Nov 22, 2006 | 03:11 PM
funkdamonkman
So I shouldn't have to worry about my tires/car on the 200mi drive back home?
Old Nov 22, 2006 | 05:04 PM
DavesZ#3's Avatar
DavesZ#3
No, if the car is tracking straight down the road without a lot of pull to the right, then you have nothing to worry about. It's mainly a psycological thing - you KNOW the steering wheel should be straight when you're going straight down the road.
Old Nov 22, 2006 | 06:38 PM
This is the steering linkage coupler. A mechanic will remove the coupler. Straighten the steering wheel. Put the coupler back on.
Old Nov 23, 2006 | 08:27 AM
funkdamonkman
Thanks guys.
aarrgghh
May 1, 2022 11:04 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
dragon11689
Sep 7, 2015 02:47 PM
