What lug nuts to use with sevas s-stars?
Old Nov 28, 2006 | 10:04 AM
litlechina's Avatar
litlechina
Default Oem lugs fit aftermarket rims?
wondering if the oem lugs and lock set will work for aftermarket rims? with a smaller diameter socket?
or will i need aftermarket lugs?
thanks
im getting sevas s-stars
Old Nov 28, 2006 | 07:58 PM
litlechina's Avatar
litlechina
can anyone help?
Old Nov 28, 2006 | 09:46 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Originally Posted by litlechina
can anyone help?
You can use OEM lug nuts on after market wheels, but on some wheels you will have to use a thin socket to turn the lugs. Places like Discount Tires have thin sockets. You will have to request them. Thin sockets are also available for purchase at stores such as Auto Zone, but most of them are made for impacts or torque wrenches. It's actually not a bad idea to pick up a torque wrench since aftermarket wheels require frequent checks when you first put them on. As for aftermarket lugs such as the ones with the tapered rings made from light weight composite materials, you can not use an impact to tighten or install them on OEM wheels. Most quality lug sets will run you around 120-250 for the set. If you don't want to spend that much you can go with a cheaper set made from Muteki or Kyokugen.
Old Nov 28, 2006 | 11:43 PM
litlechina's Avatar
litlechina
thanks a lot I really appreciate your help.
I think im gonna try out the thin sockets for now...as i have the oem wheel locks and would like to keep those on
thanks!
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
samansharif
Sep 25, 2015 12:31 PM
