vdc/tsc
Old Dec 2, 2006 | 02:20 AM
tractng's Avatar
tractng
Default vdc/tsc
Guys,
I have done some readings but just making sure.
If I get the right tire profiles (245/35/19, 275/35/19) I won't have any problems with it?
I am planning to lower using the s teins springs too.
Tony
Old Dec 2, 2006 | 02:42 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
You'll be fine...no worries...I think around 65% of Z/G owner run that application. It is even suggested by Volks and Stillen as the proper fitment for plus sizing.
Old Dec 2, 2006 | 03:23 PM
guitman32's Avatar
guitman32
I just ran each in a tire size calculator. Your speedo error % are as follows:
Front: 0.8% fast
Rear: 0.4% fast
This is a perfect setup, assuming the widths are where you want them. It will not upset VDC. The tire calculator I used is here:
http://www.miata.net/garage/tirecalc.html
Edit: I used 225/45/18 and 245/45/18 as the stock tire sizes.
Old Dec 2, 2006 | 03:25 PM
zand02max's Avatar
zand02max
You shouldn't have any problems Tony, I have the exact same setup tires. Oh, and BTW, its TCS not TSC,
bb1314
Mid-Atlantic
49
Feb 12, 2008 05:56 PM
Chebosto
Jul 24, 2003 09:48 AM
