wheel spacer help!!!
Old Dec 3, 2006 | 10:49 AM
brandonanix's Avatar
brandonanix
Default wheel spacer help!!!
I need a spacer for my wheels, to bring them out 20mm, however if I get an adapter (with studs) the factory lugs will be sticking out of the adapter since 20mm isnt thick enough to clear factory studs. should I just use the donut type spacer or what?? Ive heard that the donut spacers are not safe!?!?
Old Dec 3, 2006 | 10:28 PM
brandonanix
BUMP* please help!
Old Dec 3, 2006 | 10:45 PM
socal_g_sedan's Avatar
socal_g_sedan
20mm less stud is not safe...don't do that. use the hubcentric ones...
Old Dec 3, 2006 | 11:09 PM
Z33Benny's Avatar
Z33Benny
get the Project Kics 20mm spacers, with a 20mm spacer your stock wheel studs shouldnt be sticking out past the spacer, and if they do, it wont be much at all. Also, if anything is sticking out past your spacer, just make sure that your wheels allow for that extra bit of wheel stud to clear.
Old Dec 4, 2006 | 06:16 AM
brandonanix
where can I get the project kics?
Obadabot
Jun 18, 2023 11:31 PM
