Question about tire size
Old Dec 4, 2006 | 10:36 AM
k1prototype's Avatar
k1prototype
Default Question about tire size
Has anyone run a 225/40/18 & 245/40/18 tire instead of the 45 series our cars come with?
I want to know if there is any downsides to this?
Old Dec 4, 2006 | 11:05 AM
The overall tire height is wrong.
Old Dec 4, 2006 | 11:12 AM
k1prototype
What would be the negative effect of running something with a smaller series?
Old Dec 4, 2006 | 11:17 AM
MoodDude's Avatar
MoodDude
Your speedometer will be off.
HyperSprite's Avatar
HyperSprite
Mad Scientist
Positives would be slightly quicker acceleration.
Cons, Speedo would read faster than you are going, they will look small on the car, ride will be rougher and have higher chance of damaging the wheels, the fronts will be even more stretched looking than they already are.
Chris
Old Dec 4, 2006 | 11:18 AM
It changes the ride height and handling. Members do lower the 350Z but there is a proper way to do it.
Old Dec 4, 2006 | 11:55 AM
k1prototype
Flipping things the other way around.
(F) 235/40/18 – 2.25% fast
(R) 255/45/18 – 1.3% fast
Would this be ok?
Old Dec 4, 2006 | 12:11 PM
guitman32's Avatar
guitman32
Read this thread, the first and most easy to access:
https://my350z.com/forum/wheels-and-tires/231823-03-track-model-wheel-question.html
Do a search and you will find many answers.
Old Dec 4, 2006 | 12:41 PM
k1prototype
https://my350z.com/forum/showthread.php?t=231823
I have been for a while now.
Sometimes you just want to get a straight answer instead of searching through thread after thread.
Would there be any rubbing issues using a 255/45/18 in the back since everybody is using a 255/40/18?
Old Dec 4, 2006 | 05:50 PM
guitman32's Avatar
guitman32
I dont think there would be any rubbing issues, but you are missing the point. The 40 and 45 numbers are aspect ratios, which are exactly that, ratios...specifically the ration of sidewall height to tire width. Therefore, a 45 aspect ration on a 245 tire is not the same as a 45 ratio on a 255 tire.
Now, the Z has various traction control/stability systems depending on what model you have (ie track has VDC, base has none). These systems use the stagger (difference in overall wheel/tire diameter) to calculate when the tires are spinning and when you are losing grip. Whenever you make a change in tire size or wheel size (or both), you have to make sure you maintain as close to factory stagger as possible so as not to upset these systems.
So, the end goal is to keep the sidewall height given a set diameter wheel as close to stock as possible. This is where tire size calculators come in. You obviously understand this as you have listed the speedo errors below. The 255/45/18 size works fine, but in my experience, it tends to run a bit tall...actual tire sizes are unfortunately not very constant given a listed aspect ratio. Depending on the tire you choose, it could be right on, but I would stick with a 255/40/18 rear. I have run this setup on a Michelin Pilot Sport and Falken Azenis RT615, and I can tell you that the inflated tire diameter is extremely close to stock...a 255/45/18 in these same setups would have been taller than stock. I know some might disagree, but this is simply my experience.
Hope this helps.
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
Paul.
Oct 16, 2015 07:34 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
