Looking for a Good set of 3mm spacers
Old Dec 17, 2006 | 10:10 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Default Looking for a Good set of 3mm spacers
Anyone have any suggestions? I need about 1 mm to clear the stoptech brakes I am planning on getting, and figure the extra 2mm will be for insurance.
This is for my G, not a Z, but they have the same 5 lug pattern.
Dave
Old Dec 17, 2006 | 10:21 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
There is no such thing...
Best to get a 5mm H&R or Eibach spacer set... They include new hub bolts...
But best thing to do is get a HubCentric spacer... The smallest is 10mm tha tEibach makes... next is 15mm that both H&R and Eibach make...
Old Dec 17, 2006 | 10:55 AM
Amiricanmade's Avatar
Amiricanmade
is HubCentric the brand?
Old Dec 17, 2006 | 11:59 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
No such thing as a good 3mm spacer, or no such thing as any 3mm spacer? Because I can go on eBay and find plenty of 3mm spacers, for example, this one but I wouldn't really trust all that much on eBay as being good. I was wondering if there was an equivalent that was of good quality.
Dave
Old Dec 17, 2006 | 12:24 PM
Jason@Performance
Performance Nissan
Those are not hubcentric... You should at least use longer wheel studs with them if you are going to use them...
Those are better then the old cast ones that used to be floating around...
Find some hubrings to use as well...
Old Dec 17, 2006 | 01:59 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Define hubcentric, and also, many people have said that with 5mm spacers, you still have plenty of room on the lug bolts, so 3mm should be even more room...
Old Dec 17, 2006 | 02:42 PM
Jason@Performance
Performance Nissan
These are the 3, 5, 8 mm spacers that used to be floating around... havent seen them that much lately... but the material can compress and lead to problems like hub bolts snapping and wheels flying off...
This (below) is a Hubcentric spacer, which center bore of the spacer matches the bore of the wheel hub on the car, then the part sticking out matches the center bore of the wheel (factory wheels are hubcentric to the factory wheel hubs)...
when putting on smaller spacers that do not have the hubcentric part on it the wheel looses the hubcentric support and the hub bolts can be shiered off and your wheel will go flying off...
Old Dec 17, 2006 | 03:30 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Ah, ok, that makes sense, now. Obviously, it's the much better solution.
Thanks
Dave
Old Dec 17, 2006 | 04:44 PM
Jason@Performance
Performance Nissan
safer...
Old Dec 17, 2006 | 06:34 PM
JETPILOT's Avatar
JETPILOT
The H&R 5mm spacer is hubcentric!
http://www.mynismo.com/products/?id=4182
JET
Old Dec 17, 2006 | 06:36 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
I just ordered it. Now I'm trying to convince myself that I can put a $4500 dent in my CC for a Stoptech BBK as a Christmas present to myself...
Old Dec 17, 2006 | 06:41 PM
Jason@Performance
Performance Nissan
Both H&R & Eibach 5mm spacers are "Hubcentric" to the hub on the car, but not to the wheel... They do not have the extra hubcentric part sticking out...
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
