Curious about wheel/rims weight/weigh? Read here!
Old Jan 8, 2007 | 10:17 PM
Mazinger Z's Avatar
Mazinger Z
Default Did you weigh your rims/wheels? Post weight here!
Mods: You can make this a sticky if you wish. I think it would be helpful to a lot of people. I also made the title easier to search.
If you've ever weighed your rims, please post your sizes, tires and weight.
I just weighed these (on a bathroom scale-should be accurate to +-1lb though):
Stock 06 rims:
18x8.5 (F) with stock Potenzas: 46lbs
18x9 (R) with stock Potenzas : 52lbs
Volk LE28n:
19x9.5 (F) with Toyo T1S 255/35/19: 41lbs
19.10.5 (R) with Toyo T1S 275/35/19: 46lbs
Old Jan 12, 2007 | 03:30 PM
Mazinger Z's Avatar
Mazinger Z
bump...no one has ever weighed their rims?
Old Jan 12, 2007 | 04:38 PM
plumpzz's Avatar
plumpzz
Work XD9
18X9 20lbs
18X10 21lbs
Old Jan 12, 2007 | 11:03 PM
Armitage's Avatar
Armitage
http://www.wheelweights.net/
Old Jan 13, 2007 | 12:00 AM
onebadfyvo's Avatar
onebadfyvo
Originally Posted by Armitage
Thanks for the link. 21.5 lbs. f / 23 lbs. r for me. Not bad at all.
Old Jan 13, 2007 | 12:02 AM
DJShan209's Avatar
DJShan209
i want some pretty light 19' inch rims, any suggestions? Volk? Works?
Old Jan 13, 2007 | 12:34 AM
plumpzz's Avatar
plumpzz
CE28N. Light 19'' rims.
Old Jan 13, 2007 | 12:40 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
http://www.6061forged.com/store/Product.aspx?pid=5
From the wheel weights website they are the lighest 19's at 15.0 lbs
Old Jan 14, 2007 | 11:24 PM
Armitage's Avatar
Armitage
At 7.5" wide though, they are pretty thin.
Old Jan 25, 2007 | 11:42 AM
shanecrosby's Avatar
shanecrosby
Axis Shine
19x8.5 = 26lbs
19x9.5 = 27lbs
Is this pretty light for the wheel width? Also OP, how are those Toyo's working out for you?
Attached Thumbnails Curious about wheel/rims weight/weigh? Read here!-axis_shine.jpg
Old Jan 25, 2007 | 12:06 PM
sry110's Avatar
sry110
I recently purchased a set of PIAA rims with toyo T1R tires, and my main concern was the weight of the PIAA/Toyo combo vs. the weight of the 2006 Stock Rims / Bridgestone RE040 combo. Per the wheel and tire weights published by the respective wheel/tire manufacturers, the PIAA/Toyo combo will be a couple pounds lighter on each corner. However, the increased diameter and wheel width will tend to increase the rotational inertia of the wheel/tire combo because more of the weight is pushed out to a larger radius, so performance-wise my 'upgrade' may be a wash in regards to acceleration. However the gain in traction should make the upgrade worthwhile.
Anyway my point is, since two equally sized tires made by different manufacturers can vary in weight, I think it is also a good idea to consider tire weight in conjunction with wheel weight. I say this because a lot of performance-oriented individuals here like to focus on the nuances of 18 lbs per wheel vs. 18.5 lbs per wheel.
Old Jan 25, 2007 | 12:31 PM
plumpzz's Avatar
plumpzz
Honestly, my 20lb wheel feels just like the 26lb wheels lol.
Old Jan 25, 2007 | 12:33 PM
sry110's Avatar
sry110
d'Oh!
Old Jan 25, 2007 | 06:13 PM
z-u-later's Avatar
z-u-later
Originally Posted by bugsbbunny
Stock 06 rims:
The '06 rims are 18x8 in front & 18x8.5 in rear.
Old Jan 25, 2007 | 06:30 PM
ctwentytwo's Avatar
ctwentytwo
ADVAN RGII:
F: 18x9 (19.2 lbs)
R: 18.10 (19.8 lbs)
With proof to boot.
Old Jan 26, 2007 | 10:25 PM
Armitage's Avatar
Armitage
x4 for all four rims is an extra 24lbs of rotational mass. Might not sound like a lot, but similar cars with similar drivers, only difference being the wheels, 26lb rims will lose.
Old Jan 26, 2007 | 10:46 PM
plumpzz's Avatar
plumpzz
I bet. No when i picked them up there was a noticible weight difference, but driving around i didnt notice anything.
Old Jan 27, 2007 | 07:44 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the majority of the weights on that site are completely wrong
Old Jan 27, 2007 | 10:58 AM
davidf's Avatar
davidf
Originally Posted by ctwentytwo
ADVAN RGII:
F: 18x9 (19.2 lbs)
R: 18.10 (19.8 lbs)
With proof to boot.
Damn.
Old Jan 27, 2007 | 11:31 AM
Mazinger Z's Avatar
Mazinger Z
Oops, my bad, those are the sizes I meant hahah
