Offset Question
Old Mar 29, 2003 | 08:11 AM
OP Z's Avatar
OP Z
Default Offset Question
What is the effect if the offset is too low? Does the wheehell seem to protrude from the wheel well? How about if it is too high? Will the tire appear to be too recessed?
Old Mar 29, 2003 | 01:39 PM
rodH's Avatar
rodH
Default Re: Offset Question
YEP, YOU GOT IT!!
Old Mar 29, 2003 | 04:09 PM
OP Z's Avatar
OP Z
Someone on this forum recommeded no more than 35 mm offset. Even if you go up to 40 mm, that is less than 0.2 inches difference. I can't believe that you can see a 0.2 inch difference.
Has anyone used a 40 mm offset? Do you have a pic?
Old Mar 29, 2003 | 04:29 PM
shaneotool's Avatar
shaneotool
It depends on the width of the tire. What size tire are you thinking about.
Sometimes it's easy to get wrapped up in the offset, like a few millimeters more or less is a deal breaker. But 10mm is only .39 inches.
Old Apr 1, 2003 | 07:34 AM
HREWheelMaker's Avatar
HREWheelMaker
10mm can make or break the look of a car- and we haven't even started to talk about how it can affect handling...
Old Apr 1, 2003 | 05:08 PM
Brad4rdHay's Avatar
Brad4rdHay
Im paying big bucks to have my iForged wheels's offsets changed (out 10mm front, in 5mm rear) I deff can see that small a differrence.
Old Apr 1, 2003 | 06:15 PM
shaneotool's Avatar
shaneotool
Yeah, I guess you're right.
If your on a budget constraint and are just trying to get wheels that will fit, maybe you could go with an offset that is not ideal. But if you're going for that "look" then a few millimeters can make a difference.
I'm looking at wheels with a +23f and +24r on 8.5 and 9.5in widths. I think that will sit me right at the fender.
Old Apr 1, 2003 | 07:10 PM
Ohio350z's Avatar
Ohio350z
Do a search for a wheel offset calculator on google and you can calculate how much the wheel will move in our out.
Old Apr 1, 2003 | 07:12 PM
Stone Z's Avatar
Stone Z
http://toy4two.home.mindspring.com/offset.html
Old Apr 1, 2003 | 07:16 PM
shaneotool's Avatar
shaneotool
Man, I've worn that offset calculator out.
Old Apr 1, 2003 | 07:18 PM
Stone Z's Avatar
Stone Z
You and me both!
Old Apr 1, 2003 | 09:53 PM
rodH's Avatar
rodH
Originally posted by Stone Z
You and me both!
ME TOO!!!
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
