114.3x5 what EXACTLY does that mean
Old Mar 30, 2003 | 01:27 PM
wadd3456's Avatar
wadd3456
Default 114.3x5 what EXACTLY does that mean
Stupid question huh.
This is somewhat off the subject, but unless I can find a wheel spacer for 12-15bux a pop I am going to make my own.
Reason I need to know what the 114.3 signifies is so I can properly place the bolt holes on the part. I "think" that distance represents the width between one bolt and the bolt 2 away from it.
But in all honesty all i want is the diameter of what is shown below.......
Old Mar 30, 2003 | 01:46 PM
LS350Z's Avatar
LS350Z
Charter Member #56
Well if the red line is suppose to represent the centers of the lug circles then you are correct.
Old Mar 30, 2003 | 01:48 PM
wadd3456's Avatar
wadd3456
Yeah the red line is the center of the lug circles, but that DIA is not 114.3, there is no way. Its way too small.
Old Mar 30, 2003 | 02:17 PM
rodH's Avatar
rodH
it refers to the distance between each bolt (center to center).
Old Mar 30, 2003 | 03:18 PM
jak's Avatar
jak
Here is a drawing that should explain. Hope it helps.
Jeff
Old Mar 30, 2003 | 03:30 PM
jak's Avatar
jak
Default Re: 114.3x5 what EXACTLY does that mean
Assuming the radius drawn is the center of the lugs, the diameter is 114.3mm plus 1/2 the bolt diameter or 120.6mm.
Jeff
Old Mar 30, 2003 | 04:07 PM
cheeves's Avatar
cheeves
The bolt circle diameter=114.3 hence radius of 57.15 . Center of circle (axle), 5 holes 72 degrees apart. Top bolt in cartesian coordinates...x0, y57.15..next bolt(CW)..x54.15, y17.66...etc.
Trig out the triangle once and you can very easily figure all locations.
Hope this clears this up!
Old Mar 30, 2003 | 05:46 PM
redlinez's Avatar
redlinez
WADD,
I believe our wheels are hub-centric and making a spacer will be more difficult than figuring out where to drill the holes. Look at H&R Springs web site at their spacers and you will see what I mean. The raised ring centers the wheel. Without that your wheel may vibrate.
I'm sure they will be out of your price range but will much better than a flat plate, if that was what you had in mind.
Bob
Old Mar 30, 2003 | 05:56 PM
wadd3456's Avatar
wadd3456
Yeah i took the wheel off tonight and figured that out. Oh well, it was a nice thought. Id have to shop down a piece of aluminum ona lathe, and I really dont feel like doing that right now!
Old Mar 30, 2003 | 06:01 PM
cheeves's Avatar
cheeves
EDIT...should read x54.35, y17.66
Old Mar 31, 2003 | 07:16 AM
Sudou's Avatar
Sudou
this should help, the line indicates 114.3 length.
Old Mar 31, 2003 | 08:22 AM
wadd3456's Avatar
wadd3456
Hmm, so which one of you is right. haha
Old Mar 31, 2003 | 05:50 PM
cheeves's Avatar
cheeves
Well,
Seeing that I'm a machinist and I've been doing this for 20+ years..
Old Apr 1, 2003 | 07:31 AM
HREWheelMaker's Avatar
HREWheelMaker
If the 'red line' in the first drawing is representing the center of the lug holes, this is correct when we're talking about vehicle applications. P.C.D. = Pitch Circle Diameter
The calculation should not include the through-hole diameter, it is taken at the center of the hole. You could drill a large through-hole (for example, to utilize a shanked lug nut), and still have the correct P.C.D. A typical though-hole is .625" for automotive use.
Cheeves has it figured out.
Cobraredz
May 12, 2014 03:10 PM
mrZ
Wheels Tires
Oct 10, 2011 01:37 PM
