2005 18" fitment question
Old Jan 22, 2007 | 10:46 AM
tony1628's Avatar
tony1628
Default 2005 18" fitment question
I have a 2005 350z euth w/OEM 18" wheels. I want to see if this will fit and can I use the OEM tires with this set of wheel.
Stern ST-4
Bolt pattern : 5x114.3
Offset : 35 mm
Finish : Pro Titanium
Or do I need 20mm offset.
Thanks
tony
Old Jan 22, 2007 | 10:49 AM
leykias's Avatar
leykias
i think 20mm would sit more flush with the fenders....
with the 35mm your wheels would sit more towards the rotors.
Old Jan 22, 2007 | 10:57 AM
tony1628's Avatar
tony1628
so with less offset the wheel will stick out the fender more?
Old Jan 22, 2007 | 11:44 AM
tropicalypso's Avatar
tropicalypso
Yes.
Old Jan 22, 2007 | 12:09 PM
Use a offset calculator to compare the current and new wheels. With the numbers, check the car with a tape. Do you clear the calipers and suspension.
What size tires fit 8.5-inch wheels? Check Tire Rack for recommendations.
Old Jan 22, 2007 | 05:39 PM
tony1628's Avatar
tony1628
Default what do you think? which one for a silverstone 350z
he first one is
ADR Battle exec (+$74.00 more)
the second is Stern ST-4
they are both 35mm offset.. I will mount with OEM tires... I think it should be ok...
thanks for all the inputs!!!
Old Jan 22, 2007 | 06:56 PM
tony1628's Avatar
tony1628
Default which is better 20mm or 35mm?
I need all your experts out there to answer on final question..
18x8.5" front and rear... should I get 20mm or 35mm offset..
THANKS
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
