Will these fit?
Old Jan 23, 2007 | 01:21 PM
JoeyFyed's Avatar
JoeyFyed
Default Will these fit?
Fronts are 225/45ZR18, Rears are 255/40ZR18.
Now the question is, will those size tires fit on my stock 2006 rims. Which are 18" x 8.0 Front, and 18" x 8.5 Rear.
Usually, I would keep the factory size, but a friend of mine has some tires laying around for a cheap price.
Thanks alot, btw the tires are Michelin Pilot Sport, Z rated performance tires from an M3
Old Jan 23, 2007 | 01:24 PM
kwiker's Avatar
kwiker
Shift_Dorifto
rears are not as tall as oem (245.45.18) but you might not have problems. I don't remember the % diff that is allowed.
I didn't go ape $hit on you for not searching b/c you have been here for over 3 years...but you can search to find out the answer.
Old Jan 23, 2007 | 01:31 PM
JoeyFyed's Avatar
JoeyFyed
Is it really that difficult to get an answer, I asked the forums cause im on here everyday, i dont post too much but w.e. I trust you guys before any other place
Old Jan 23, 2007 | 01:47 PM
Reality350's Avatar
Reality350
Here.
Tire Size Calculator - tire & wheel plus sizing
Tire size calculator
I believe there is a sticky with regard to tire size and how much of a diff is allowed, maybe 3%?. I remember finding it in a search.. lol
Good luck,
R
EDIT: LOL! I just found it by going into the proper forum.....
https://my350z.com/forum/wheels-and-tires/203755-will-these-tires-work-with-my-vdc-enabled-car-read-here.html
Old Jan 23, 2007 | 01:50 PM
JoeyFyed's Avatar
JoeyFyed
Originally Posted by Reality350
Here.
Good luck,
R
https://my350z.com/forum/showthread.php?t=203755
Thanks alot man, appreciate it. So the diameter difference is 2.44%, anyone think i'll run into any problems with them?
Old Jan 23, 2007 | 01:56 PM
kwiker's Avatar
kwiker
Shift_Dorifto
you should be ok, i think 3% is the number...since i thought it was that before reality350 posted and he said the same thing i'm pretty sure now that it was 3%.
Old Jan 23, 2007 | 07:04 PM
Originally Posted by JoeyFyed
Sorry if im not up to par with 15,000+ post. I spend most of my time reading here, not posting. Where have you been? Obviously in front of a computer...
LOL. I prefer that the rear tires are 10mm taller than the front with VDC, but this set-up will be OK with TCS.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
