Same tire size front and back?
Old Apr 2, 2003 | 11:08 AM
Super22LL's Avatar
Super22LL
Question Same tire size front and back?
I am planning on keeping my factory 17" wheels. My question is... we all get two different size tires front and back, has anyone looked into having the same size tires front and back when it's time for replacements? I would like to have the same size front and back so I could rotate my tires front to back. I would like to find out if I put the wider tire size all the way around, would I have any clearence problems with the front wheel well. If anyone has any information on this, please let me know.
Old Apr 2, 2003 | 11:20 AM
DarkTalon's Avatar
DarkTalon
There is a maximun size you can put in front, I think about 255 mm.
It's preferable to go wider in the back in a RWD car. I know that it's a ***** to have two different tire sizes but you have to live with it.
Old Apr 2, 2003 | 11:22 AM
Jspec350z's Avatar
Jspec350z
I ran 245/50/17 winterfires for the 1st 1400 miles with no ill effects. Although they do handle like ****!!
Old Apr 3, 2003 | 03:45 AM
j's350z's Avatar
j's350z
You still can't rotate with the 17"s unless you take off the tires and switch them... The 17" wheels are wider in the back. It would handle like crap if you put the 8" wheel in the front and the 7.5" wheel in the back.....
Old Apr 3, 2003 | 04:21 AM
Super22LL's Avatar
Super22LL
That's the kind of information I was looking for. Thanks. Guess I'll have to keep like it is.
Old Apr 3, 2003 | 04:52 AM
cluofi's Avatar
cluofi
but you could still rotate them side to side, if you bought a tire that was not direction like the pirelli p zero Nero's. but side to side rotation really wouldnt be too helpful because it would wear the same way.
Old Apr 3, 2003 | 09:05 AM
ares's Avatar
ares
Veteran
the size difference isnt totally what kepps you from rotating, its the fact that the Z has directional tread, most performance tires are this way.
to rotate you have to remove the tire from the rim and mount it back on reversed, then you can move left to right and right to left. but as someone said, its not as good as rotating diagonal.
you could maybe find a tire size that will work on both rims, its not too difficult to make a tire fit both 7.5 and 8" rims, not totally ideal, but if you really wanted to...
bcoffee20
Nov 19, 2015 06:39 PM
Paul.
Oct 16, 2015 07:34 PM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
