Tires spinning too much
Old Feb 5, 2007 | 08:27 PM
LouiZ's Avatar
LouiZ
Default Tires spinning too much
I have 18s te-37 with some nitto 555 extreme. I bought the rims from a friend with the tires with 60% tread left. Besides all that, why am i spinning soo much? also my TCS seems to come on driving normal daily. Now when it comes to racing someone, the tcs will come on insanely and i would end up losing to a couple of my buddies.. Any idea guys?
Old Feb 5, 2007 | 08:29 PM
plumpzz's Avatar
plumpzz
its cold outside and those are summer tires
Old Feb 5, 2007 | 08:33 PM
LouiZ's Avatar
LouiZ
thanks a lot plumps..i hope that corrects the problem. i guess i wont be going at it with anyone until summer comes a long.
Old Feb 5, 2007 | 08:34 PM
Jason@Riverside's Avatar
Jason@Riverside
Vendor - Former Vendor
Control your throttle better...
Tires do need to warm up especially summer tires as mentioned above...
Old Feb 5, 2007 | 08:41 PM
gsazabi's Avatar
gsazabi
Read my signature about the Nitto 555s.
The temperature has been in the 50s lately and it certainly doesn't help on those crappy Nittos.
It was a bit better today due to hot weather.
Old Feb 5, 2007 | 08:48 PM
LouiZ's Avatar
LouiZ
and i thought my stockies sucked. i seemed to launch better with my stockies over the new 555. =\.
Old Feb 5, 2007 | 09:13 PM
plumpzz's Avatar
plumpzz
my all seasons launch best in the fall. In the summer they're greasy and in the winter they're stiff. Summer tires will be horrible below 50 degrees. Around 20 degrees you definately can't gun it even in 3rd gear.
Old Feb 5, 2007 | 09:19 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
What tires sizes are you running now?
Old Feb 5, 2007 | 09:26 PM
Abishop's Avatar
Abishop
i dont really like my 555's either
Old Feb 5, 2007 | 09:27 PM
HIGHTECHZ's Avatar
HIGHTECHZ
if your new wheel/tire combo is a slightly different diameter than your stock, the tcs will think the front and rear wheels are going different speeds. That is if your fronts are correct and your rears are incorrect, or if they both are incorrect but in different amounts. If the car thinks the wheels are not in sync with each other, it will assume your rears are spinning and will engage.
Check the diameter using a wheel/tire size calculator and check with your buddy on whether his car had the tcs or not. If not, he wouldn't have noticed the problem.
This is a problem for all rwd cars with tcs when the wheels/tires are changed.
Old Feb 5, 2007 | 09:29 PM
LouiZ's Avatar
LouiZ
245 front and 275 rear
Old Feb 5, 2007 | 09:31 PM
LouiZ's Avatar
LouiZ
My buddy never had this problem. but then again, i believe he had a base model. But i'm going to need a little help with that wheel/tire size calculator b/c i never heard of that before. how can i get my hands on that?
Old Feb 6, 2007 | 04:44 AM
sluggoZ's Avatar
sluggoZ
Here ya go Loui....have fun!!!
http://www.miata.net/garage/tirecalc.html
Old Feb 6, 2007 | 06:30 AM
HyperSprite
Mad Scientist
What are your sidewall profiles?
245/??R18
275/??R18
My guess, just hearing your issues, you are running 245/40R18 in front and 275/35R18 out back. This would put your backs at a smaller diameter than the fronts and cause SLIP to come on during long sweepers on the freeway etc.
Chris
Old Feb 6, 2007 | 04:50 PM
Then turn TCS OFF.
Old Feb 6, 2007 | 05:03 PM
Kurt04Z's Avatar
Kurt04Z
I have the exact same tires and size and dont have a problem at all. I actually try to overpower them all the time and slide around corners. I think there the best tire I've ever had. Just get used to them and you might like them.
Old Feb 8, 2007 | 10:36 AM
LouiZ's Avatar
LouiZ
Thanks a lot guys for the info. yes my tires sizes are 245/40 and 275/35. With my slip turned off, it will be even worst. but whatever the case is, i hope its all b/c of the temperature.
-loui
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
