Decided on these offsets for my widebody.. what you think?
Hi guys,
I dont post here much but im ordering a set of wheels directly from Volk themselves in Japan (through a dealer here) and just wanted to confirm one last time before I send out the order. These are for the Veilside V3 widebody kit recommended by Volk:
Volk GTC 20" GOLD
Front: 20 x 9.5 +20 offset
Rear: 20 x 10.5 +10 offset
I chose the rear offset as +10 so that I have the option of adding a spacer if needed later on for the V3 widebody
The other option that Volk offered is:
Rear: 20 x 10.5 -12 offset
I figured these would be better but till I get my bodykit it will stick out too much and look ugly.. or so I believe. If any of you guys think otherwise from experience let me know.
I need to make the order by tomorrow so any suggestions would be appreciated thanks!
Volk GTC 20" GOLD
Im not planning on going FI for a long time.. so gettin 11.5 rear wheels would add weight considerably and slow the NA car down.
I want to stick to 10.5 rear and get a very low offset (-12?) to make it stick out as much as possible. I dont think I would need more than 1" spacer if I need to.
No offense but going wide body and running 20 inch rims are already going to add more weight, which will slow you down. Might as well get wider rims, probably only a couple more lbs at the most.
That's what I was thinking.
rear with 10.5 is ok if you have negative offset. However, the flare of V3 widebody kit is HUGE. You're talking about almost 2'. If possible, get 20x11 in the rear so you can put on some wider tire.
Widebody, 20' wheel? forget about performance if you don't have FI. It's more of a show car now.
