will this setup have any rubbing issues?
Old Feb 13, 2007 | 07:24 AM
bommart's Avatar
bommart
Default will this setup have any rubbing issues?
Rota 18"; Front-265/35R18 w/25mm offset, Rear-275/35R18 w/28 mm offset; tanabe suspension (1" front, 1.2" back); 2006 Z no brembos. Thanks for the help!
Old Feb 13, 2007 | 07:25 AM
sam30540's Avatar
sam30540
Most likely you won't have any rubbing
Old Feb 13, 2007 | 12:26 PM
azula's Avatar
azula
not with that wheel size, ur straight
Old Feb 13, 2007 | 08:58 PM
JETPILOT's Avatar
JETPILOT
No one can possibly answer that question withou knowing the wheels width's. So that above answers are retarted.
JET
Old Feb 13, 2007 | 09:03 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Be careful. You shouldn't rub with ^ application but double check the tire specs on the manufacture's website. Not all tires of the same size have the same dimensions.
Old Feb 14, 2007 | 03:16 AM
WalkerT's Avatar
WalkerT
Professional
I have 18x9.5 with a 25 off set and 285 35 18 rear with a 1 inch drop and no rubbing you should be fine with that set up on an 9.5 inch width rim.
Old Feb 14, 2007 | 04:04 AM
sam30540's Avatar
sam30540
JET
If you knew your *** from a hole in the ground you would that the rota wheels came in a 9.5 inch width
Old Feb 14, 2007 | 06:56 AM
bommart's Avatar
bommart
awesome...thnx guyz.
Old Feb 14, 2007 | 06:59 AM
Wholey Smokes's Avatar
Wholey Smokes
JET
He did give the tire widths, as well. You mean old man.
Old Feb 25, 2007 | 02:52 PM
hockiman90's Avatar
hockiman90
does anyone know if that combo, the rota 18 inch and 275 tire, that bommart is using as his rear would fit up front on a stock Z without requiring fender rolling?
sherm
Apr 11, 2020 05:21 PM
hulkout
Apr 28, 2017 09:00 PM
350z82
Oct 1, 2015 06:25 PM
