Will my TPS work with these rims?
Old Feb 19, 2007 | 04:25 PM
CaliTouring's Avatar
CaliTouring
Default Will my TPS work with these rims?
ADR M-Sport
19 x 9.5 rears /235
19 x 8.5 fronts /265
Old Feb 19, 2007 | 11:50 PM
CaliTouring
anyone?
Old Feb 20, 2007 | 01:43 AM
light's Avatar
light
it should work. ask the tire shop to install it for you
Old Feb 20, 2007 | 02:43 AM
sluggoZ's Avatar
sluggoZ
Your wheel guy should know if the TPS is compatible. BTW your wheel size is screwed up!
Old Feb 20, 2007 | 06:17 AM
THE TECH's Avatar
THE TECH
You can use the TPS on any wheels.
Old Feb 20, 2007 | 09:57 AM
ScrObot's Avatar
ScrObot
To make sure TPS, VDC and your speedometer work properly, you should stay within 3% of the stock wheel and tire diameter. Use this calculator to plug in the numbers and see what it says. Greater than 3% difference may make your computer think it's losing traction when it's not.
Old Feb 20, 2007 | 11:07 AM
CaliTouring
why is it screwed up?
Old Feb 20, 2007 | 11:37 AM
ScrObot's Avatar
ScrObot
I think he's referring to the fact that you mixed up the tire widths with the rims (235 should be on the 8.5", 265 should be on the 9.5").
Old Feb 20, 2007 | 11:42 AM
sluggoZ's Avatar
sluggoZ
To clearify....some aftermarket wheels are not compatible with the TPS on the valve stem...others might require to band them around the rim.
...on your tires.....you show in your thread fronts, 265, rears 235.....is it screwed up or not!
Old Feb 20, 2007 | 12:54 PM
CaliTouring
thats my mistake its the other way around
_bit
Oct 2, 2015 07:49 AM
