couple rim ?'s
Old Feb 25, 2007 | 03:35 PM
FALLEN1z's Avatar
FALLEN1z
Default couple rim ?'s
im gonna be buying a set of rims soon and i found a deal on some 18's. im wondering if they'll be flush with the wheel well because i hate the way the stock rims are set into the wheel well.
the new rims are:
18x8.5 front with 25mm offset
18x9.5 rear with 28mm offset
will they be flush?
they also come with 265/35/18 front and 295/35/18 rear. they say that it wont rub even with an eibach pro-kit. my car is tock height. do you think it will rub?
Old Feb 25, 2007 | 04:19 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Feb 25, 2007 | 04:20 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
let me post a picture in a second:
18x8.5 +10 all around
245/40 front
255/45 rear ( slight rub)
so on a 18X9.5 a 25 mm offset will be close to flush as mine
im on eibach prokits also
ldawg32's Avatar
ldawg32
It should be pretty flush but i wouldnt go so wide with the front tire. i would stick with a 245 or 255 imo.
Old Feb 26, 2007 | 12:29 AM
redlude97's Avatar
redlude97
No, I run 19x8.5+20 and 19x9.5+30 and they aren't flush, I'm gonna try a 10mm spacer up front w/ 245s and a 20mm spacer in the rear with rolling to fit my 285s in the rear
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
