Removing wheels
Old Feb 28, 2007 | 11:18 AM
Cloud's Avatar
Cloud
Default Removing wheels
What do you guys use to remove your wheels?
I used the factory lug wrench but it scratched up the rims.
I have a torque wrench torque wrench only tightens and I don't think there's any way to reverse it unless i open it up and mess with the gears.
New to this kind of stuff so don't flame me.
Thanks.
Old Feb 28, 2007 | 11:23 AM
MR_X's Avatar
MR_X
I use a deep socket wrench with the 6" extension. I also put some duct tape around the wrench or key to keep them from scratching the rims.
Old Feb 28, 2007 | 11:24 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
Get an extension. Also buy a set of gorilla tuner lug nuts and a set of gorilla locking lug if you got expensive wheels. Those lugs/locks comes with keys that extends out and will clear your wheels. Plus it's hard to steal rims what are bolted down with tuner lugs AND tuner wheel locks. Just a bit more safe IMO.
Old Feb 28, 2007 | 11:31 AM
SOCAL350's Avatar
SOCAL350
This is no problem..........anytime you can buy new tools its a happy day. Thin wall socket with some tape like said above.
Old Feb 28, 2007 | 11:40 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
Why not just get some gorilla tuner lug nuts. It's safer since thieves will need a key instead AND he will also get to use the key as an extension. Win win situation IMO. Thieves will want everything - even stock rims.
Old Feb 28, 2007 | 11:51 AM
dmroberson's Avatar
dmroberson
I use a 4-way lug wrench, with the key to my McGard spline drive lugs. No worries about scratching.
Old Feb 28, 2007 | 01:48 PM
FAIRLADYZ_MANnE's Avatar
FAIRLADYZ_MANnE
any links to the
"gorilla tuner lug nuts and a set of gorilla locking lug"
j/w
Old Feb 28, 2007 | 02:17 PM
VO...'s Avatar
VO...
Administrator
+1 on the 4-way lug wrench..
Old Feb 28, 2007 | 02:30 PM
DavesZ#3's Avatar
DavesZ#3
Plastic coated deep socket.
Old Feb 28, 2007 | 02:57 PM
Old Feb 28, 2007 | 04:32 PM
Swiffer's Avatar
Swiffer
I wrapped some electrical tape around the socket. Works fine for me.
Old Feb 28, 2007 | 04:53 PM
KornerCarver's Avatar
KornerCarver
I use my impact wrench and a deep socket to remove the lug nuts. Then I use a torque wrench to put them back on the car.
Les
Old Mar 3, 2007 | 08:25 PM
jdo's Avatar
jdo
what do you set the torque wrench at to tighten them back up? what lb/ft setting? thanks
Old Mar 3, 2007 | 08:29 PM
jdo's Avatar
jdo
nm...i found the answer
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
