Decided What Wheels And Tires To Get
I am geeting the MSR Wheels 88r. I got the 19x8.5 in the front and the 19x10 in the back. The back has a 3" lip. The tires are Nitto 555's. The fronts are 245's and the backs are 275's. I was wanting better wheels, but I decided that good tires are more important. The offset on the back wheel is 40. I have read in a few places that spacers can make the lip appear larger. Will I be able to use spacers on this wheel to make the lip larger? I don't know very much about spacers.
The offset in the rear looks very high. You may want to look for one around the 20-30 range so that you don't have to run spacers.
Spacers don't make the lip appear larger, it pushes the wheel outward... toward the wheel well.
I also hear that those Nitto's don't work very well in wet weather.
40 offset is fine in the rear. You can run a 295/35/19 if you wanted with that offset and wheel width - depending on what shocks you run. If you run coilovers that have the spring actually go over the shock, then you're screwed
