Tire patch w/o removing the tire
Old Mar 19, 2007 | 05:46 PM
VN_350z's Avatar
VN_350z
Default Tire patch w/o removing the tire
The rear tire on my car had a nail. So I stopped by Midas today for a tire patch since it's right by my work place. Unlike other tire patches I've done, they actually patched it from the outside of the tire. The tech guy pulled out the nail. Then he pushed a rubber string with glue (half the width of a pinky) through the hole. About 2 inches went inside the tire and he cut off the extra from the outside
I was like WTF. I actually tested with the soap and it stopped leaking. They said they warranty for 3 months. Anyone had this done ?
Old Mar 19, 2007 | 06:05 PM
THE TECH's Avatar
THE TECH
I've seen this done on other cars before. I guess it works, but I wouldn't drive around with it like that on my car.
Old Mar 19, 2007 | 06:06 PM
DavesZ#3's Avatar
DavesZ#3
I've had it done before but not on the Z's tires. I certainly wouldn't trust it at extended high speeds.
Old Mar 19, 2007 | 06:07 PM
VN_350z's Avatar
VN_350z
yeah, i plan to bring it to tire place for proper repair. Oh well, wasted 15 bucks
Old Mar 19, 2007 | 06:09 PM
Sean's Avatar
Sean
it's a plug, if you aren't going to go crazy with, it should hold without issue.
Old Mar 19, 2007 | 06:10 PM
sumfknguy's Avatar
sumfknguy
lol.. that’s like everyday tire patching here in New Orleans the way I grew up.. to actually take a tire off and patch it from the inside is.. well.. not heard off. I've had it done on other cars of mine in the past and they have held up just fine.. now, with the Z... I think I would go the "normal" route..
Old Mar 19, 2007 | 06:47 PM
DavesZ#3's Avatar
DavesZ#3
Plugs are not the preferred method of repair, the patch is. Sometimes you have to do a little emergency field repair and the plug will come in handy. I'm thinking of buying a plug kit myself after what I saw yesterday. We were at a out-of-the-way autocross location (Belle Chasse NAS) when a guy in a S2K had a tire going flat. No spare, small electric pump couldn't fill it fast enough. He was looking to borrow a wheel/tire that would fit so he could drive back to civilization to find someone to fix it. Turns out somebody had a plug and fixed him up in minutes. It's the next best thing to the forbidden alternative - leak stop goo. NEVER use that crap!
Old Jul 19, 2007 | 06:03 PM
Cool 350Z's Avatar
Cool 350Z
I just put 2 plugs in one rear tire I use a mushroom plug
no glue no mess and they work great
I'v used theys plugs on my motocycle with NO problems the plug
lasted the life of the tire and on my past cars to. It seem I have a habbit
of picking up screws and nails must be where I work..
Old Jul 19, 2007 | 06:04 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
I would do the patch from the inside. Plugs will also void your tire warranty.
Old Jul 19, 2007 | 07:03 PM
Chad68's Avatar
Chad68
I just had my right rear patched by Les Shwab or however they spell it. Guy told me 37 bucks. I was like wtf for a plug? I never paid more than 10 bucks for a 3 minute plug job. He said the right way to do it is from the inside with a patch.
I had plugged one of my fronts on the Z before and had it up to 150 mph briefly before and it didn't blow up or anything and never lost air. I totally don't recomend driving 150 mph let alone on a plug but it worked fine in my case.
However the best way aside from buying a new $300 tire or two, is to patch them from the inside. If I would have known they were gonna have to remove the tire from my wheel, I would have just plugged it myself, to avoid the chance of them trashing my wheels. I always carry plugs and a mini compressor in my car and truck, as well as fix a flat in a worse case scenario.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
