9.5 +5 with a 285? No problem...
Added some 25mm spacers and rolled my fenders on saturday and ended up with flushed wheels. Probably coulda gone another 5mm but didn't want to push it. Running a 285/35/19 dropped on Z HTechs with a shaved springmount, and SPC rear camber set at -1.5. Next up is some spacers for the front wheels, anyone think 8.5 -5 will work with a 245/35/19?
I think the camber pic is a little deceptive because the ground is sloping down. The camber is set at -1.5, which is within factory specs, and a good balance between performance and tire wear. I could probably knock it down to -1 and still clear as I have ~5mm of clearance from the fender. Heres a more accurate representation of the camber
bcoffee20
Nov 19, 2015 06:39 PM
Looks bad.
