HELP! Keep losing tire pressure but don't know how?
Originally Posted by HondaKiller
If its not the valve stem, and it passes a water test, then your rim is bent. A bent rim can cause an undetectable slow leak. They have this red goo they can line the tire with when they put it on rim that will stop the slow leak from a tweaked/bent rim. It's nasty stuff though, once you put it on its nasty getting it off the rim when its time for new tires. I would suggest buying a new rim if that is the case.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Tochigi_236
Sep 27, 2015 03:40 PM
