Will these wheels fit? HP Racing Lightning 18"
Old Apr 7, 2007 | 06:24 PM
FairladyZ06's Avatar
FairladyZ06
Question Will these wheels fit? HP Racing Lightning 18"
I have a set of HP Racing 18 x 8 " wheels with 225/35 Kumho's on it. Will these fit on the Z? The specs are 5x100 and 5x114.3 ... does that mean its both patterns or available separately in those patterns? I want to put this on my Z. I know I need new tires but is it even possible? Do I need spacers, and modifications to make it fit? Thanks guys.
Old Apr 7, 2007 | 06:51 PM
FairladyZ06
I believe the offset is +38 on it, so I am assuming right off the bat that I need 20mm or more spacers. I would like to keep the TPS on the new wheels, is this possible?
Old Apr 7, 2007 | 07:43 PM
nooooorb's Avatar
nooooorb
No, it will not fit/work. 225/35-R18 will be the wrong overall diameter for the Z. If you want to use your HP Racing wheels, you'll need to stick with the stock tire setup - 225/45-R18 and 245/45-R18. If you want to have the wheels/tires flush with the fender you'll definitely need the 20 mm spacers. If you want to stay a little bit more conservative, then go with 15 mm spacers.
Also, you'll only be using the 5X114.3 holes.
Old Apr 8, 2007 | 08:25 PM
FairladyZ06
Thank you for the info. I guess I'll get the 20mm spacers, assuming kic's are the best? any recommendations? also I am getting new tires, perhaps some Goodyear F1 Eagle's or Michelin Pilots ... dont know yet. Any info would be great, thanks guys.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
SharX59
Sep 30, 2015 10:54 AM
