Tanabe teaser drop
Old Apr 15, 2007 | 02:29 AM
Zincognito's Avatar
Zincognito
looks great and you are right about needing the spacers....
Old Apr 15, 2007 | 09:35 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Originally Posted by whitenizmo
Any camber issues or alignment problems?
It's definitely driveable but my camber needs to be brought back close to spec. I'm getting a rear camber kit installed and 4 wheel alignment within the next week.
Old Apr 16, 2007 | 09:49 AM
dutchboy350Z
Finally some go
Yeah 15mm all around would change the offsets to +22F/+23R
Old Apr 16, 2007 | 10:05 AM
whitenizmo's Avatar
whitenizmo
I heard for all springs combo doesnt need a camber kit, just need alignment by hand, since computerize alignment might not be able to adjust it back to OEM specs...check before you spend another 400$ on cambers..
Old Apr 16, 2007 | 10:08 AM
Shift_Z33's Avatar
Shift_Z33
+1 on spacers. Looks great though
Old Apr 16, 2007 | 10:20 AM
wasuber's Avatar
wasuber
Thumbs up
looks great man! did you measure all the way around before and after you dropped? Let us know how the ride is, lookin good!
Old Apr 16, 2007 | 10:43 AM
dutchboy350Z
Finally some go
Camber kit is definitely needed. Just by looking at it I would estimate of having 3 or 4 degrees of negative camber. Our OEM camber arm can only adjust plus or minus 1/2 a degree. The SPC camber kit is plus or minus 4 degrees.
Old Apr 16, 2007 | 10:46 AM
dutchboy350Z
Finally some go
No but I would estimate a gap of two inches in the back and a inch in the front before the drop. I'll measure what it has settled to in a few days.
BTW the ride so far is less harsh than before (not a whole lot). I haven't really tested the handling yet as far a taking turns. I definitely feel like it hugs the pavement a lot more.
Old Apr 16, 2007 | 02:17 PM
dutchboy350Z
Finally some go
Thanks to HKSPWRDZ from Fresh Alloy for the PS. My new avatar.
Old Apr 16, 2007 | 07:35 PM
Alberto's Avatar
Alberto
Cranky FI Owner
^^Hot pic man...
Old Apr 16, 2007 | 07:38 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Wouldn't you want to wait for the springs to settle before you get an alignment?
Old Apr 16, 2007 | 07:40 PM
dutchboy350Z
Finally some go
definitely, that's why I haven't gotten the alignment yet. From what I hear one week is plenty to let it settle.
Old Apr 16, 2007 | 07:41 PM
dutchboy350Z
Finally some go
Originally Posted by Alberto
^^Hot pic man...
That's what I thought ... DB FTW!
BTW you can post pics of the install on this thread if you want.
Old Apr 16, 2007 | 07:50 PM
BornSlippyZ's Avatar
BornSlippyZ
Looks great! I have the same springs on my ride... you will definitly feel more of a "hug on turns". The only complaint is that it needs a camber kit like you described! I have only had uneven ware minorly on the front tires!!! other than that no problems!
Old Apr 16, 2007 | 09:30 PM
Korki Buchek's Avatar
Korki Buchek
propers.
Old Apr 18, 2007 | 08:11 AM
dutchboy350Z
Finally some go
Default A few more, five days later.
Everything should have settled by now.
Old Apr 18, 2007 | 09:45 AM
helldorado's Avatar
helldorado
Nice! How long until you put the spacers on?
Old Apr 18, 2007 | 10:07 AM
  #38
dutchboy350Z
Finally some go
Probably early may, not really in a hurry since it's not my DD.
Old Apr 19, 2007 | 05:44 PM
  #39
g0tb00st's Avatar
g0tb00st
how much lower did it get after the springs settled?
Old Apr 19, 2007 | 09:50 PM
  #40
dutchboy350Z
Finally some go
I would say no more than a 1/4 of an inch. Hopefully that's it. Right now I've got like a half inch to spare before rubbing starts to become an issue. Rear fenders are going to be rolled regardless.
