What size tire can I fit?
Old Apr 13, 2007 | 05:08 AM
one350zfan's Avatar
one350zfan
Default What size tire can I fit?
I have 18 x 10 on the rears. I have some worthless Nitto 275/35/18 on now and they look way too stretched! Looking to replace with some street DR's and was wondering what tire I could fit. I'm more concerned with launching and not so much about handling.
Here's some pics to show how much room I have under my mild drop.
Attached Thumbnails What size tire can I fit?-lots-of-pics-047-large-.jpg   What size tire can I fit?-lots-of-pics-050-large-.jpg   What size tire can I fit?-lots-of-pics-051-large-.jpg   What size tire can I fit?-lots-of-pics-049-large-.jpg   What size tire can I fit?-lots-of-pics-048-large-.jpg
Old Apr 13, 2007 | 05:14 AM
Mike Wazowski's Avatar
Mike Wazowski
what is the offset of the wheel? looks like it is sticking out about 3/4 of an inch or so.
Old Apr 13, 2007 | 05:46 AM
one350zfan's Avatar
one350zfan
^ Not sure about the offset. Its whatever Dazz Motorsports recommends for the Z. They're the main distributor for Racinghart so I went with their recommendation. I posted more pics above to show, but the wheel is about flush with the edge of the fender.
Old Apr 13, 2007 | 05:59 AM
Mike Wazowski
I would do a 295/30-18 but you could possibly fit a 305/30-18 depending on how much space you have inside.
Old Apr 13, 2007 | 06:15 AM
one350zfan's Avatar
one350zfan
^ Would it just be some minor fender rolling if the 305 ended up being a little snug? I don't think I'm in a position to have a shop test fit one.
Old Apr 13, 2007 | 06:16 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
295s tops but 285s should be perfect.
Old Apr 13, 2007 | 06:20 AM
Mike Wazowski
the part I would be most worried about with the 305 is the inside rubbing on your shock.
Old Apr 13, 2007 | 07:08 AM
one350zfan's Avatar
one350zfan
What would be an equivalent size to 295/30/18
http://www.mickeythompsontires.com/s...em=SportsmanSR
Old Apr 13, 2007 | 09:54 AM
one350zfan's Avatar
one350zfan
^Bump, anyone know the answer
Old Apr 13, 2007 | 10:01 AM
redlude97's Avatar
redlude97
you need a 25x11.5R18 to match that sized tire, the closest is the 26x12R18
Old Apr 13, 2007 | 10:06 AM
one350zfan's Avatar
one350zfan
^IYO would it fit?
Old Apr 13, 2007 | 10:14 AM
kaybee650's Avatar
kaybee650
well the recommended size for 18x10 would usually be 275 40 thats what i have from tire rack when i ordered my rims. just to keep the speedo within range
Old Apr 13, 2007 | 10:16 AM
redlude97's Avatar
redlude97
It'll fit, and you should be okay as long as you don't wheel hop too much off the line, but I wouldn't recommend putting them on before getting to the track as you'll likely rub on turns
Old Apr 13, 2007 | 10:30 AM
one350zfan's Avatar
one350zfan
See, the thing is, I only put about 300 miles on my car a month. And when I do take it out its to drag race and fool around. I not into taking turns hard so I don't care how the tire reacts in those situations. I'm looking for a tire that when I hit the nitrous on the street it will hook but I'm not spending $400 plus per tire for Pilots or something similar. These MT's are $211 per and from what I gather from hot rod forums seem to hook well.
I'll probably give them a try because they have to be better than my crappy nitto's
Old Apr 13, 2007 | 03:06 PM
coachk's Avatar
coachk
Default What tire size will fit
Jay.. The nite we raced at Bradenton I had 295/35/18 BFG D/R's on a 10"wheel..No problem with fitment but my car is not dropped at all. JEGS has them for 255.00 per tire
Old Apr 13, 2007 | 06:06 PM
eltness350's Avatar
eltness350
The Untouchable
tires.com where i got mine.....$225 a piece!!!
http://www.discounttiredirect.com/di...95&ar=35&rd=18
Old Apr 14, 2007 | 05:18 AM
one350zfan's Avatar
one350zfan
Cool! My cars a beast on the strip with the Hoosier DR's but is pretty much worthless on the street with these garbage *** Nitto's.
Old Apr 14, 2007 | 05:20 AM
one350zfan's Avatar
one350zfan
Ooh, $50 cheaper... thanks!
Old Apr 14, 2007 | 05:33 AM
coachk's Avatar
coachk
I left my DR's on and have had no problems with them on the street. Definitely would recommend them over the Nittos.You going to Bithlo this weekend.Do you have the website for that racetrack? If not I'll be back in Bradenton next weekend hopefully with my Torque converter put in so I can get a better launch and keep up with you.
ablaine
Nov 29, 2016 10:13 AM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
