Widest tire for Nissan OEM 8.5" rear Track Wheel
I've been fortunate to locate a set of pristine OEM Rays 18" Track wheels. The stock tires were 225 fronts and 245 rears. Do any of you guys have wider front and rear tires on these wheels? I was hoping to put 235/45 on the front and 255/45 or 265/45 on the rear. I don't want any tire bulging or create any adverse driving conditions. If 265 is too wide for the 8.5" wide please give me your opinions. Thanks.
I don't see how you can squeeze a 275 mm wide tire on an 8.5" (215.9mm) wide wheel. I figured out how to use this site after making my post. I can do 255 and possibly up to 265 without any major headaches.
http://www.1010tires.com/TireSizeCal...?action=submit
John
lots of autoX ppl use 275's on the OE 17" rims (if you're in stock class, you can't change your rim diameter or width dimensions)...so lots of ppl put on 275's - performance is good...but the tire can looked buldged a little bit.
I'd run 245/40/18 on the front and a 245/45/18 in the rear. It would provide the most neutral handling characteristic, and as long as your tire choice is a sticky one, you'll probably run just as quick as somebody squeezing 255+
I just looked at tire choices, the Bridgestone RE-01R and the Azenis RT-615 is available in a 245/40/18 and the 245/45/18
An even better tire if you want to stick with street selection is the 255/40/18 Yokohama AD07 which is $290ea from tirerack.com and have better grip than the RT-615's...
Originally Posted by scotts300
What data supports your claim that the Yoko AD07 has better grip (and in what sense) than the RT615? Thanks...
Thanks to everyone for giving me your opinions on the rear tire width for the Track 18" OEM rear wheel. Actually I have found quite a few makers of the 235/45/18 and 255/45/18 size tires. I'll post some pics next week after I get the wheels mounted to my Z,
Local SCCA WDCR autocrossers and a few NASA time trial guys.
Put your 275's on al 4 corners. I have an 03 and bought a 2ed set of stock rims. I mounted 275's on the 4 stock rear rims when going to Hpde. This gives me the best turn in performance on the corners.
