Work 18x10.5 +19, 18x10.5 +14
Why didnt you runt he 275/35's in the rear, you have staggered offsets so you cant rotate the tires anyhow.
Shift_Dorifto
on
Rotate the tires??? Screw trying to get every last mile out of your tires...that is for suckers. You can always just dismount the tires and swap sides, or move them around whichever way you want. I do that every 3k to keep from getting really bad camber wear before the tire is used up since i run around 2.0.
<---is a sucker, according to himself.
Originally Posted by drumma022
Wrong tire size?! I have done plenty of research on this fitment and used it on the last set of wheels without any problems. The tire is NOT too narrow for the wheel width. VDC and ABS has no problem at all with the tire diameter. The only thing that may be wrong is that this wheel and tire combo does not suit the bandwagon.
on
Advan also states that the 265/35/18 is suitable for a 10.5" wheel for the Advan Neova.
For this setup, I chose the 18x10.5 +19 A-Disk (100mm lip) in hopes that it will clear big brakes and the 18x10.5 +14 O-Disk (112mm lip) for maximum dish in the rear. I could have matched the front and rear to make rotating even easier, but that was a benefit I had to give up for a better fit.
I haven't had a chance to take super hard turns to test if it will rub since it was raining last night on my way home.
on
on
Update on setup:
No Rubbing under hard G's.
Drove around some or Orlando's worst roads and no rubbing.
RT-615s Grip amazing in the dry, but suck in the wet!
I hope to get an alignment and detail this week before a trip to Miami - I will post my specs when done.
on
Originally Posted by derekinthez
yeah, props for not following all the lazy, scared, and whining little sheep on this forum. Baaaaaaaaaaaaaaaaaaaaaaaaaahhhhhh!
Looks hot! They really do look like 19s due to the fitment.
