Silver TE37's on SB
Old Apr 19, 2003 | 09:49 PM
HXS's Avatar
HXS
Default NICE...
but give us SPECS!!!
19x9.5 front +22 offset???
19x10.5 rear +22 offset???
r these correct???
Old Apr 19, 2003 | 10:03 PM
FLY BY Z's Avatar
FLY BY Z
Lotus, if you don't mind, what are the specs to that wheel/tire setup? Backspacing, wheel/tire widths/heights, etc. Thanks and looks great!
edit: oops, second page questions.
Old Apr 19, 2003 | 10:04 PM
john350Z's Avatar
john350Z
COOL!!!!!!!!!!!!!!!!!!!
once again, looking good!!!!!!!!!!!!!
hardy-looks like lotus has 19x8.5 22mm fronts and 19x9.5 22mm rears.
Old Apr 19, 2003 | 10:11 PM
fairladyZ in Japan's Avatar
fairladyZ in Japan
Default lug nuts....
john350z and lotus...
John has black lug nuts on his Z ... and lotus has silver..
Which ones did you use... stock ? light weight ? why the difference ?
thanks
Old Apr 19, 2003 | 10:43 PM
john350Z's Avatar
john350Z
fairladyz-
lotus probably has the silver lug nuts provided by mackin industries (volk racing supplier in america).
i bought a set of the volk racing lug nuts, which are very lightweight. they either come in anodized black or anodized blue.
phdeez has a set of the anodized blue on his 350z with the standard offset silver te-37s.
Old Apr 19, 2003 | 10:53 PM
lotus's Avatar
lotus
Yep just 19 X 8.5 19 X 9.5 +22
I am using the lugs that came with the wheels. Not sure If I want to go black or not.
Old Apr 19, 2003 | 10:55 PM
lotus's Avatar
lotus
Oh yes I did install the Pressure monitors...
Old Apr 20, 2003 | 08:47 AM
lotus's Avatar
lotus
What do you guys think about the suspension settings?
Old Apr 20, 2003 | 10:26 AM
deviousZ's Avatar
deviousZ
droooooool........
I love the set up man the ride hight is nice does it rub at all??? love the wheels!
Old Apr 20, 2003 | 11:05 AM
Brad4rdHay's Avatar
Brad4rdHay
I would raise the rear end untill you have an equal front/rear drop. I think it would look better with the stock's slight downward angle. I also would do this by raising the rear and NOT dropping the front more because i think the Z looks silly too low being the "tall" design that it is
TW, your car looks awesome.
Old Apr 20, 2003 | 11:27 AM
ZZtopp's Avatar
ZZtopp
Did you mount them where they mount on the stock Rays, or did you have to use bands?
Old Apr 20, 2003 | 11:33 AM
lotus's Avatar
lotus
No rub problems. The sensors are mounted on the valve stems. Just need to swap them out. I put the ones that came with the Rays on my track wheels.
Old Apr 20, 2003 | 07:43 PM
AAAA's Avatar
AAAA
whered you get your rims from?
Old Apr 20, 2003 | 09:15 PM
HXS's Avatar
HXS
Lightbulb
IMO, i usually like the fronts just a tad lower than the rears... so according to your current set-up, i would lower the front just a tad more, maybe a quarter inch more to 3/4"...
Old Apr 20, 2003 | 09:39 PM
lotus's Avatar
lotus
Wheels were purchased from Streetsports.
Thats what Im thinking also.
Old Apr 21, 2003 | 12:54 AM
Just-Cruising's Avatar
Just-Cruising
Default Weight?
Can you post the weight of your wheel setup? Thank you!
Old Apr 21, 2003 | 10:26 AM
theZman's Avatar
theZman
It looks great! Ok, time to go order some TE37's. They look fabulous!
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
hardkicks
Sep 20, 2015 12:28 PM
