17" Rims in the Front and 20" in the rear
So before you get to typing that I'm crazy, hear me out.
In alot of concept car drawings the small tire is larger then the front.
I've seen the smaller/larger setup on street cars and I always liked it.
Someone please explain why this is a bad setup?
I am no tire and wheel expert.
17" by widest recommended in the front (thinking 245 or 255)
19 or 20" by widest recommended in the rear (thinking 305 or 315)
I'm willing to buy an aftermarket suspension kit and some camber hardware & fender rolling, to get this to work.
Thanks in advance.
Thanks in advance.
you'll have some crazy oversteer to try and get rid of..
rear sidewall will have no play whereas front will have lots of play and grab.
1" stagger for rear engine cars because the smaller sidewall holds the weight of car well.
stick to a 1" stagger at most, otherwise its going to feel weird driving, very oversteer happy
Thanks for the responses.
It might look good in a drawing, but it's not a good idea in reality.
DSPIEL the fact that you know where to get animated dancing deodorant let's us all know how much time you must have on your hands.
Next time I need some animated cursors I'll look you up bit^h.
Guys who talk sh*t on boards are the same guys who sit in the corner very quiet in person. It's safe behind that keyboard huh?
What you never asked a question genius?
2003 Enthusiast
Built Motor, Single Turbo, HKS-VPRO
13lbs low boost :17lbs high boost
Miscellaneous: 3.3 Gear, Carbon LSD, Greddy Boost Controller, Knock Amp, Plenum, 880CC Injectors, Custom 3" Exhaust and all of the obvious stuff along the way
2003 Enthusiast
laff its one of the emoticons on the website..took me all of 3seconds, second your username makes you look like a huge troll fyi
2003 Enthusiast
2003 Enthusiast
Talking $hit #1. DSPIEL the fact that you know where to get animated dancing deodorant let's us all know how much time you must have on your hands.
Talking $hit #2. Next time I need some animated cursors I'll look you up bit^h.
Talking $hit #3. What you never asked a question genius?
