Help with spacers
Old Apr 26, 2007 | 04:17 PM
Nexx's Avatar
Nexx
Default Help with spacers
My GT-7's are 9.5" with 245/35/19's and +22 offset. The rears are 10.5" with 275/35/19's with +30 offset. Can I get spacers for a bit more aggressive stance without rubbing? Which spacer sizes should I consider. I know there are 5mm 10mm 15mm etc.
Thanks in advance for your suggestions.
Old Apr 26, 2007 | 04:29 PM
Nihilation's Avatar
Nihilation
An 8mm spacer in the rear should be safe. I probably wouldn't touch the fronts.
Old Apr 26, 2007 | 04:46 PM
redlude97's Avatar
redlude97
Are you willing to roll your fenders? Most of the guys running super low offsets had to roll or run skinny tires
Old Apr 26, 2007 | 05:35 PM
Nexx's Avatar
Nexx
i would prefer to stay away from rolling. i do run slightly stretched tires so that helps. maybe ill go with 10mm rears and 5mm in the front.
Old Apr 27, 2007 | 12:38 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
I feel your paint. I went for +28 rear to stay away from having to roll my fender in case I drop later. In your case I'd say go for the 5mm and not risk it.
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
