confused with tire choice
Old Apr 27, 2007 | 08:21 PM
Shinin350z's Avatar
Shinin350z
Default confused with tire choice
I have spent weeks reading and trying to figure out what tires will fit,calculators etc. That will not have my VDC kick in. My wheels are 20x8.5 +25 & 20X10 +25. If you have 20's can you post what tire setup you have. Thanks
Old Apr 28, 2007 | 08:37 AM
blaukal's Avatar
blaukal
https://my350z.com/forum/wheels-and-tires/203755-will-these-tires-work-with-my-vdc-enabled-car-read-here.html
it's not the size of the rims/tires per se; it's the difference in the size of the rims/tires relative to stock and to each other. the sticky thread at the top of this forum explains it all, much more clearly than I ever could.
Old Apr 28, 2007 | 08:52 AM
Question
What size tires are you considering?
Old Apr 28, 2007 | 01:35 PM
Shinin350z's Avatar
Shinin350z
Toyo proxes T1R 245/35-20 & 285/30-20. But it would make the front slightly bigger than the rear. A VDC no no. My friend has an 06 with the same setup with no issues. I'm trying to stay away from 30 series if I can.
Old Apr 28, 2007 | 04:42 PM
Nihilation's Avatar
Nihilation
Just run a 30 series tire on all four and you'll be ok.
Old Apr 28, 2007 | 05:04 PM
Shinin350z's Avatar
Shinin350z
I was just trying to see if I can run a 245/35-20 for the front. Les schwab says that it would be the same size as the rear 285/30-20 = 26.80. But if it would throw off the vdc its not going to work. There is a $120 difference between the 35 series and the 30 series.
Old Apr 29, 2007 | 06:49 PM
Shinin350z's Avatar
Shinin350z
Does anyone else run Toyo T1R 245/35-20 in the front have problems with the VDC? Thanks
ablaine
Nov 29, 2016 10:13 AM
kyin
Oct 15, 2015 05:54 AM
