Great!
Old Apr 22, 2003 | 08:32 AM
publisher's Avatar
publisher
Sport Z Magazine
Default Great!
Yesterday added SO3's all around and now have low air alert blinking incessantly.
Actual pressure up front [225/45R18]: 32-33
Digital reading: 28-29
Actual pressure in rear [245/45R18]: 34-35
Digital reading: 29-30
Air pressure was measured 3 ways and they all read about the same [2 readings mechanical, 1 reading digital]. When the tires heated up a bit, each reading went up 2 pounds.
Is this normal?
Old Apr 22, 2003 | 09:02 AM
droideka's Avatar
droideka
Default Re: Great!
Is this normal?
You have to get the PSI up over 35 for the warning light to go out. Trust me. Do this and drive around for a bit and your problem should go away.
Old Apr 22, 2003 | 09:23 AM
FlyingToaster's Avatar
FlyingToaster
Question on tire pressure monitor. The brochure of the Z says it is "real time." I am assuming they put a device inside the tires attached to the wheel to take that measurement.
1- Is this correct?
2- If you change wheels, and order them online, they come fitted and balanced; what one would do to keep the tire pressure monitor?
Thanks in advance,
Old Apr 22, 2003 | 09:29 AM
publisher's Avatar
publisher
Sport Z Magazine
1- Is this correct?
Bob speaking: Correct
Bob speaking: Wheels remain stock [Touring 6MT] and very special care was given when new tires were mounted so as not to damage the sensors.
Thanks in advance,
Old Apr 22, 2003 | 09:31 AM
publisher's Avatar
publisher
Sport Z Magazine
Default Re: Re: Great!
Thanks, I'll give this a go.
sales@czp
Sep 23, 2019 03:30 PM
