Wheel pressure sensor
Old Apr 22, 2003 | 04:30 PM
RBMOTORING350Z's Avatar
RBMOTORING350Z
Default Wheel pressure sensor
I just got my Z and plan to upgrade the wheels soon. Quick questions, what do you guys do with the wheel pressure sensor when you upgrade your stock wheels?
Old Apr 22, 2003 | 04:52 PM
ares's Avatar
ares
Veteran
most rims will take them just fine. best solution is to ask on here and someone might already have them and tried it.
if not, then your gonna get dashes in the reading, and itll always take you to that menu when you start, as tho they were low, but luckily it wont beep.
Old Apr 22, 2003 | 07:10 PM
2003z's Avatar
2003z
Originally posted by ares
if not, ..., and itll always take you to that menu when you start, as tho they were low, but luckily it wont beep.
No it won't. You sure like to put a lot of bad information out.
Old Apr 22, 2003 | 07:20 PM
Brad4rdHay's Avatar
Brad4rdHay
uh, actually hes right.
Old Apr 22, 2003 | 07:39 PM
3 FIVE O Z's Avatar
3 FIVE O Z
Well maybe they are both right I do not get that paticular menu everytime (at all) when I start the car, and when I do goto that menu it is dashes. Go figure it's not like your going down the track and get into a chicane and think "Am I losing traction in my left front tire because the air pressure is too low and not warmed up yet?" I don't think so.... unless you are really racing and need to be **** with your tire pressure it is just a novelty item for us novices/racer wannabies.
Old Apr 22, 2003 | 08:06 PM
ares's Avatar
ares
Veteran
Im not putting out incorrect info bud, I have rims on my car right now, no tire pressure monitor. when I turn on the car I get front pressure menu, it has 2 dashes for each side, hit the menu button and I go to rear, same thing, one more time and Im at the last used screen.
and it does not beep.
not sure what yours does, or why it would be different.
Old Apr 23, 2003 | 04:25 AM
2003z's Avatar
2003z
mine cycles through like normal, and always goes to the last selected display, usually speed or temp. Yes there are dashes, but it doesn't take me to that menu on startup.
Old Apr 23, 2003 | 11:43 AM
ares's Avatar
ares
Veteran
perhaps it has to do with the last status. my tires were underinflated before I removed the sensor, so maybe it stayed with the last known setting.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
