Stock wheel weight
Old May 6, 2007 | 03:26 PM
Beaker02's Avatar
Beaker02
Default Stock wheel weight
Anyone know our stock wheel weight, and any ideas and how much above or below we would feel the weight difference?
Old May 6, 2007 | 03:31 PM
IzReAl's Avatar
IzReAl
Originally Posted by 05-Z
(depending upon air pressure, almost any nissan tire + rim combo will be around 40-60 lbs each)
17" base rims F: 17x7.5 = 23.26 lbs and R: 17x8.0 = 24.140 lbs
18" track rims F: 18x8.0 = 18.1 lbs and R: 18x8.5 = 18.62 lbs
18" perf/touring rims F: 18x8.0 = 27 lbs and R: = 18x8.0 = 27 lbs
18" LMGT rims F: 18x8.5 = 18.3 lbs and R: 18x9.5 = 18.8 lbs
19" LMGT rims F: 19 x 8.5 = and R: 19x9.5 = around 22 lbs
all 20 lug nuts: 2.6 lbs
Old May 6, 2007 | 03:52 PM
DavesZ#3's Avatar
DavesZ#3
You won't feel any difference. There may be some measurable performance difference in the 1/4mile or 0-100mph runs.
Old May 6, 2007 | 06:57 PM
Go 30-pound 20-inch wheels. Performance be dammed.
Old May 6, 2007 | 07:21 PM
ke0ki2k's Avatar
ke0ki2k
stock fronts are 24.4 stock rears are 25.8 on the 35th ann. or 2006-2007 base/enth./touring models. if you keep close to OEM sizes (18x8 front 18x9 rear) you can lose near 10 pounds per wheel, and aftermarket summer tires are lighter too. losing 50 pounds of rotating mass is pretty easy. i went with 18x9.5 front 18x10.5 inch rear wheels with 255/275 (wayyyy wider than stock) and still lost 28 pounds.
Old May 6, 2007 | 08:11 PM
Beaker02's Avatar
Beaker02
Cool. So my stocks that are coming off are 27lbs, and the SHIPPING weight of my new wheels are 25lbs, and an inch wider. So, i'm thinking i'm not going to feel any real difference. Thank you all for the replies. And thank you all for not blasting me for asking already posted info.
Old May 6, 2007 | 08:21 PM
Shinin350z's Avatar
Shinin350z
He should go with the 30lbs 20" rims. They look a lot better than the 27lbs 18" touring rims. 3lbs=performance loss?
Old May 7, 2007 | 12:28 PM
Beaker02's Avatar
Beaker02
I just saw my shipping weight on my new wheels. 15lb total per wheel. Wonder if i'll feel a weight difference?
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
Depravity
Oct 1, 2015 04:49 PM
