Spaced on Project kics and Slammed on Tannabe GF210s
Finally some go
1" drop in the front and 1.2" in the rear. I just installed 20mm spacers in the rear. Front spacers will be installed within the week. My offsets went from 37 to 17 in the rear. Fenders are rolled and so far no rubbing.
Finally some go
Originally Posted by Tubbs
did you end up getting the studs cut?
Finally some go
Originally Posted by THE TECH
Nice drop and spacing. Never been a fan of those rims though.
Finally some go
Originally Posted by Phantom Menace
Nice...but you know, you could've just bought either open or extended lug nuts?
Finally some go
Originally Posted by umzzz
what a ricrmobile!
jk looks good nice and flush
Finally some go
Originally Posted by Driven1
Nice. That looks much better. Glad to see you got that little stud issue out of the way.
Originally Posted by dutchboy350Z
Probably need to read my other thread. The lug nuts that hold the spacer in place are open. The OEM factory studs are too long for the spacer NOT the wheel. In other words the factory studs extended past the spacer which means my wheels didn't sit flush against the spacer.
Really, really, nice car!
Finally some go
Ohhh. In that case, you did the only thing you could do?! Bravo! I know on the OEM rims, there are small crevaces or "caves" that would've fixed that problem, but you've got aftermarkets.
Finally some go
Originally Posted by jtabraham
Looks great!
350Z_Al
Oct 29, 2020 07:44 PM
