what do you guys think (spacer ?)
I have 19x8 +30offset in the front of my Z. Needless to say, they tuck inside the fender BAD. I was thinking about going with 20mm spacers to get it close to being flush with the outside of the fender. What do you guys think? 20mm the best?
Originally Posted by Mr_Drifter
do you think I would have to roll my fenders since I'm dropped 1" in the front?
edit ^ dayn it you beat me too it.
so do both you guys think I should go 25mm as well?
How To Measure?
The widest point of your tire and wheel combination is usually the outside diameter of the tire sidewall. Using a ruler with the straight edge flush with the face of the tire, measure the gap between the outer face of the tire to the inside lip of the fender as shown in the diagram. This will determine the thickness of the spacer you will need.
5MM = 0.197 INCH
8MM = 0.313 INCH
10MM = 0.393 INCH
12MM = 0.473 INCH
15MM = 0.590 INCH
20MM = 0.787 INCH
25MM = 0.983 INCH
http://www.ichibausa.com/whspad.html
you can also use this calculator and find set ups you know dont rub up front:
http://www.1010tires.com/WheelOffsetCalculator.asp
for example im pretty sure 9.5 +22 doesnt rub use that as a reference point
