Tire feathering on 05
Old May 29, 2007 | 02:27 PM
07Z06's Avatar
07Z06
Default Tire feathering on 05
Is the tire feathering issue covered under warranty on an 05 model? I've found a lot of info on the 03 and 04 but not on the 05.
Old May 29, 2007 | 02:32 PM
NissanZfan's Avatar
NissanZfan
05 does not have feathering, neither does my 03 after I got a proper alignment. That is what you will need to do, and no it's not covered under warrantee...that program expired a while back and I believe only the 03, 04 were covered. Take it to the dealer or whomever you trust and get it set to the specs.
How bad is the feathering? I have some NASTY pictures of feathering.
Old May 29, 2007 | 03:01 PM
The warranty is the same for all 350Zs: 36 months/36,000 miles.
Old May 29, 2007 | 03:12 PM
NissanZfan's Avatar
NissanZfan
Not true. Nissan put out a bulletin, even giving away free tires. You should know that... I remember you commenting about how you never heard of any other car companies giving away free tires.
Alignment aren’t even covered under warrantee to my knowledge...just like brakes, clutches 99% of the time. That bulletin was an exception to the rule.
Old May 29, 2007 | 03:13 PM
NissanZfan's Avatar
NissanZfan
http://www.nissanhelp.com/Ownership/.../NTB04-043.htm
Old May 29, 2007 | 03:37 PM
True. Nissan has written several policy letters about feathering. I got free front tires and an alignment for a 2004. Not certain if the policy covers 2005, or if it has expired.
Old May 30, 2007 | 08:31 AM
07Z06's Avatar
07Z06
I've already read this but it doesn't apply to the 05 and later models. So how do I deal with Nissan on the same exact issue on an 05?
Old May 30, 2007 | 08:34 AM
DavesZ#3's Avatar
DavesZ#3
The alignment TSB was for the 03 then the 04 models. The reason the OP can't find anything on '05 models with feathering is because few if any really had the problem. Compared to the 03 and 04 models, all years since them have been featherless.
Old May 30, 2007 | 12:37 PM
350zx6r's Avatar
350zx6r
I think im having that same problem with my 06.... sometimes it gets really noisy. my only concern is that I replaced all 4 tires for falken. im taking it to the dealer this week.
Old May 30, 2007 | 03:03 PM
DavesZ#3's Avatar
DavesZ#3
My Falken 615s are a lot noisier than my Michelin PS2s but not as bad as the Potenzas were when they were truly feathered.
Old May 30, 2007 | 04:32 PM
wilson7136's Avatar
wilson7136
Good luck. I went to the mat with NNA. However, since I went back to a softer tire (yes Potenza's) I have had no issue. I am convinced that 350's do not like a hard tire.
Old May 31, 2007 | 11:15 AM
NissanZfan's Avatar
NissanZfan
How bad is the feathering, do you have pictures you can post? When is the last time you got an alignment? Getting an alignment every few months is part of maintenance, so what exactly do you want Nissan to do? I think if you get a good alignment, you should be good to go and have no feathering problems. Hell my tires on the infiniti are half feathered, but that is my fault due to being lazy and not rotating tires and not getting an alignment for years. Good luck.
Old Jun 2, 2007 | 04:38 AM
07Z06's Avatar
07Z06
Is this bad enough?
Old Jun 2, 2007 | 05:52 AM
DavesZ#3's Avatar
DavesZ#3
That picture tells nothing about feathering. Your inner tread block is worn away, that's different than feathering. Feathering is an un-even wear of the inner tread blocks. The uneven wear causes a saw-tooth pattern across adjacent tread blocks. That looks like camber wear.
BTW- it's almost impossible to take a decent picture of feathering. The only ones I've seen have been enhanced by a little dust or powder on the tire tread.
This is a photo of the typical 2003 and 2004 feathering. If you look at the inside tread, you can see the unusual wear pattern of alternating high and low blocks. This pattern is what makes the roar.
Old Jun 2, 2007 | 06:02 AM
tahoe-man's Avatar
tahoe-man
My 05 feathered but it was alignment related. The car would go straight down the road but the alignment was off so it was hard to tell anything was wrong at first.
Old Jun 2, 2007 | 06:07 AM
DavesZ#3's Avatar
DavesZ#3
^^^ Not sure what that's a picture of, but it's not tire feathering.
On a feathered tire, one end of the tread block is higher than the other end. Individual blocks are not different heights, it's the height across each block that changed. Look at the Nissan TSB for the method of measuring the tread blocks, it is done by measuring the gap at the trailing end of each adjacent block.
Here's a picture of feathering...
Old Jun 2, 2007 | 06:09 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Is this bad enough?
That's alignment wear. The tire is considered legally bald already and you need to change it.
Old Jun 2, 2007 | 06:25 AM
Thanks. My tire (above) is similar to photo that you posted. The angle of the camera is different.
Old Jun 2, 2007 | 07:24 AM
lightner22's Avatar
lightner22
My tires feathered in groups much like yours did. a group of 2-3 blocks was worn at an angle causing a horrible noise and slight vibration. It didn't really show up on my car until 15000, and I was able to squeeze 25000 out of the OEM tires. I'm still of the opinion that the problem was more tire related then suspension related, but only time will tell.
