Axis Shine
Old Jun 20, 2007 | 05:56 PM
  #41
KelekonaKustoms's Avatar
KelekonaKustoms
Originally Posted by Nails
Whoa! Hold the phone! With the +15 OFFSET in the Front, how are you dropping 1.2 inches (Eibach Sportline) without setting the fender on top of your rubber?! I have been trying for weeks to find a way drop the gap in the rear without getting coil-overs, but the Front has less than an inch gap to work with. umsracing - what is your wheel/tire application? Mine is F-245/35/20 and R-275/30/20. Perhaps you have a 30 in the Front? Also, if anyone has 20" Shines with the +15 and +20 offsets AND has lowered their Z, please let me know how you did it and what you used -- it would be a major help. THANKS.
i have the Shines in 20'' with those offsets on an eibach prokit (1 inch drop)
245/35/20 front
285/30/20 rear
cut fenders in rear, spc camber arms. NO RUBBING!!
Old Jun 21, 2007 | 09:42 AM
  #42
Nails's Avatar
Nails
245/35/20 front
285/30/20 rear
No fender cut in the front? The front fenders must be rolled at least? That must be a real tight fit. Is a 1 in. drop in the rear enough of a drop for you. I would suspect the fronts are SLAMMED. Any photos?
Old Jun 21, 2007 | 02:45 PM
  #43
redlude97's Avatar
redlude97
No fender cut in the front? The front fenders must be rolled at least? That must be a real tight fit. Is a 1 in. drop in the rear enough of a drop for you. I would suspect the fronts are SLAMMED with still a small gap in the rear. Any photos?
fronts come prerolled from the factory
Old Jun 21, 2007 | 02:49 PM
  #44
eze-edsel's Avatar
eze-edsel
glad i read this thread. i ordered 20 inch shines with 285 in the rear. and battlervison camber arms. but what is the cuuting of the fender about?
Old Jun 21, 2007 | 02:52 PM
  #45
350Z84's Avatar
350Z84
Instead of rolling the metal around the inside of the fender, it is cut.
Old Jun 21, 2007 | 02:59 PM
  #46
eze-edsel's Avatar
eze-edsel
is it nessary to cut the fender if i am only dropping it .6 in front & .5 in rear?
Old Jun 21, 2007 | 03:01 PM
  #47
redlude97's Avatar
redlude97
with a 285, probably
Old Jun 21, 2007 | 03:03 PM
  #48
eze-edsel's Avatar
eze-edsel
if i went with 275 is it nessary?
and where would i take the car to get my fenders cut?
Old Jun 21, 2007 | 03:29 PM
  #49
AxisWheels's Avatar
AxisWheels
You can run the 275/35/20. That's the great thing about the 350z's. Tons of room.
We do the 20x10.5 with +35mm offset and 285/30 and no rubbing.
Need 4 Speed does ALOT of the Shines on the 350/G35's
Old Jun 21, 2007 | 06:18 PM
  #50
Chad68's Avatar
Chad68
I have 10.5" rear with 35 offset with a 305/30/19 with no probs at all..
Welll ok it does graze the boot a tad bit once in a while
Old Jun 22, 2007 | 07:25 PM
  #51
VENOMSZ's Avatar
VENOMSZ
any fitment issues Darren?
Old Jul 2, 2007 | 06:07 PM
  #52
Ianmtx's Avatar
Ianmtx
Well I said I'd get em and I wasn't lying. Just got mine mounted.
Old Jul 2, 2007 | 06:28 PM
  #53
solidsnake's Avatar
solidsnake
VERY nice. Keep them clean. No driving in the rain
35reilly
Sep 28, 2015 07:42 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
hk350
Mar 12, 2003 01:14 AM
Heat
Feb 12, 2003 04:41 PM
