!!!!!Offset Question!!!!!
Old Jun 21, 2007 | 01:30 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Originally Posted by erickim080387
so, 85 for spacers and 90 for lugs? cool. i have rays lugs if its any different.. cuz it makes a squeaking noise whenever i loosen the rays lugs. thanks for the ultra fast response by the way. by the way, ill post some pics next monday or so, taking pics on sunday at a local meet. thakns for all your help guys!
NP
Old Jun 21, 2007 | 04:34 PM
ssgohan434's Avatar
ssgohan434
So just to make things clear, because I'm going to be doing the same thing except with project kics spacers (have studs built into them), i would bolt on the spacers and wheels... then after 25mi like suggested take the wheels off and retorque the spacers? And then put the wheels back on, and retorque the wheels after 25mi?
That correct?
Also one more question, why do you need two jackstands and a floor jack to change wheels/add spacers? Isn't the jack that nissan gives you to change to the spare tire enough? Thanks guys!
Old Jun 21, 2007 | 04:41 PM
redlude97's Avatar
redlude97
That correct?
that is the correct method, also check your wheels after another 25 miles to make sure those are torqued correctly. The reason the jack and jackstands are recommended are because the stock jack is really only meant for emergency use, and not for use on a regular basis, its weak and can fail much easier than a real jack. Its also easier to jack the car up from the differential and put it on jackstands to install the spacers
Old Jun 21, 2007 | 04:58 PM
ssgohan434's Avatar
ssgohan434
http://www.sears.com/sr/javasr/produ...Lift+Equipment
Would that be a good deal? A floor jack and 2 jack stands? Actually my cousin down the street I'm sure has 2 jackstands, but i dont think he has a floorjack.
Old Jun 21, 2007 | 08:12 PM
dutchboy350Z
Finally some go
Yeah that's a good deal. Just be careful when you release the pressure to lower it. Do it VERY slowly. One 1/4 turn too fast and floor jack will let off FAST.
Old Jun 21, 2007 | 10:45 PM
erickim080387's Avatar
erickim080387
Originally Posted by dutchboy350Z
NP
ok... i couldnt fine anyone to install these. i think theres a different method for h&r spacers. i think you have to replace the existing studs with the extended once and put the spacer on top of that and then the rim over the spacer. the extended studs are not attached on the spacer. anyways. this might actually look different when its actually installed correctly, but i just tried test fitting over the existing studs and it looks retarded IMO. its not flush, it sticks out of the fender.
by the way heres my rim specs again...
19x8.5 +25
19x9.5 +29
Attached Thumbnails !!!!!Offset Question!!!!!-zzz.jpg   !!!!!Offset Question!!!!!-zzz1.jpg
Old Jun 21, 2007 | 11:51 PM
gregtotheb's Avatar
gregtotheb
19x8.5 +25
19x9.5 +29
wow. thats too much right there. man. my bad are you gonna try to get it installed anyway?
Old Jun 22, 2007 | 12:50 AM
redlude97's Avatar
redlude97
there is something wrong with your suspension there, your camber is way outta wack, looks like you have positive camber and the top of the tire sticks out more than the bottom
Old Jun 22, 2007 | 06:50 AM
dutchboy350Z
Finally some go
Either that or you have to let the suspension/wheel settle with all of the cars weight over it. Even if you jack it up 6 or 7 inches (without the tires coming off the ground) your camber will change from negative to positive
Old Jun 22, 2007 | 07:01 AM
redlude97's Avatar
redlude97
there is no way his setup actually looks like that, my offset is more aggressive and my tires are wider and it tucks with a fender roll
Old Jun 22, 2007 | 07:24 AM
helldorado's Avatar
helldorado
With spacers you'd be at 9.5" +9 which is pretty much the same as a 10.5" +22, a nice flush fit.
Did you remove the concentric ring before seating the spacer over the hub? Because it looks like you're bumped out about the thickness of that hub ring. Spacer is designed to fit over your stock hub, not the concentric ring.
Old Jun 22, 2007 | 09:42 AM
erickim080387
yeah nevermind then. LOL i was too lazy and didnt have the correct jack. i used the spare tire jack and have side skirts so it was a bich. yeah it wasnt installed correctly. i just put the spacers over the existing studs. thanks for the response. i realized i have to take off the caliper, then take off the existing studs replace them with the extended studs my spacers came with put the caliper back on then spacer then rim. too much work. any idea how much this will cost at a mechanics shop?
Old Jun 22, 2007 | 10:06 AM
dutchboy350Z
Finally some go
Few hours worth of labor ... $80 per hour = around $160
Old Jun 22, 2007 | 10:12 AM
erickim080387
thanks. i think im going to try doing myself with a friend. my friend knows a lot about mechanics, so ils see what i can do before i get it professionally done. ill keep yall updated!
Old Jun 22, 2007 | 03:05 PM
erickim080387
so i was just passing by my mechanics shop and dropped in for an estimate on installing these. he wants 45 per wheel. thats 180! haha i might just install these with a friend, if not sell them..
Old Jul 2, 2007 | 09:15 AM
erickim080387
oh well... i finally got it done...
Old Jul 2, 2007 | 09:19 AM
ssgohan434's Avatar
ssgohan434
^ Looks good!
Old Jul 2, 2007 | 09:35 AM
  #38
erickim080387
hehe thanks!
another one~
Old Jul 2, 2007 | 10:35 AM
  #39
ssgohan434's Avatar
ssgohan434
What size spacers/offsets did you end up going with? Fender cutting/rolling?
Old Jul 2, 2007 | 12:17 PM
  #40
erickim080387
rim specs: 19x 8.5 and 9.5 +25F and +29R
spacer spec: 20mm ALL around
rolled rear fender.
i think i couldve went with 25mm, but 20 looks perfect..
