!!!!!Offset Question!!!!!
Old Jun 20, 2007 | 12:27 PM
erickim080387's Avatar
erickim080387
Default !!!!!Offset Question!!!!!
hi i am currently running 19x8.5 +25 (front) & 19x9.5+29 (rear) on my car. if i install 20mm spacers front and rear, will it sit flush or stick out of the fenders too much or even at all? also, will i need fender rolling or cutting? thank you.
Old Jun 20, 2007 | 01:44 PM
Question
Do you have 20 mm between the outer edge of the tire and inner edge of the fender?
Old Jun 20, 2007 | 01:45 PM
erickim080387
i cant really tell. thats why im asking.
Old Jun 20, 2007 | 03:11 PM
tHisZ_bFAST's Avatar
tHisZ_bFAST
15mm and you can go flush it.
Old Jun 20, 2007 | 03:14 PM
erickim080387
so 20 will be pushing it? the only reason im wanting 20mm is i found 2 pairs for a great deal..
Old Jun 20, 2007 | 03:16 PM
Tubbs's Avatar
Tubbs
i have 18x9 22 offsets with 20mm spacers in the back and 15 in the front. Flush and work great. I also have 245's all around a 1 degree of camber.
Old Jun 20, 2007 | 04:48 PM
redlude97's Avatar
redlude97
I'm running 19x9.5+30 w/ a 285/35/19 in the rear with a 25mm spacer leaving me at 9.5 +5, and I would say they are flush
Old Jun 21, 2007 | 04:21 AM
Alberto's Avatar
Alberto
Cranky FI Owner
^^Ugghh nasty negative camber FTL
Old Jun 21, 2007 | 07:34 AM
erickim080387
lol, do z ang g have same amount of fender space? im trying to ask if it might be flush for a g but stick out of fender for a z..?
Old Jun 21, 2007 | 08:34 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
I have 20mm spacers on my rear wheels. My original offsets were 37mm in the rear, so now I'm at 17mm. My fenders are rolled, I'm dropped 1.2" in the back and my camber is at -1.6 degrees. No rubbing.
Old Jun 21, 2007 | 09:30 AM
Tubbs's Avatar
Tubbs
I like neg camber. Some people here like to turn, as opposed to going straight.
Old Jun 21, 2007 | 10:08 AM
redlude97's Avatar
redlude97
its at -1.6, thats within OEM specs, notice the pic is angled. Heres what they actually look like
Old Jun 21, 2007 | 01:00 PM
erickim080387
NICE. ok. i have one more question. i am calling all the just tires in my area for a quote to install these because i dont have a jack other than the spare tire jack and a torque wrench. one of the places actually refused to install these, saying its dangerous because the wheels will get loose and eventually fall off..? true? i am getting H&R DRS series 20mm all around by the way.
Old Jun 21, 2007 | 01:02 PM
redlude97's Avatar
redlude97
they won't fall off if torqued correctly and rechecked after driving 25 miles or so, just like wheels.
Old Jun 21, 2007 | 01:05 PM
ssgohan434's Avatar
ssgohan434
you'll be fine, unless you get some cheap ebay ones, but H&R are quality goods.
Old Jun 21, 2007 | 01:06 PM
erickim080387
yeah the only reason im taking these to just tires for installation is the torque wrench...
Old Jun 21, 2007 | 01:09 PM
dutchboy350Z
Finally some go
Or you can buy a torque wrench ($35) a floor jack and pair of jack stands ($30) and install it yourself.
Old Jun 21, 2007 | 01:20 PM
erickim080387
do you guys know what i have to torque it to? cuz just tires are actually charging a lot. i thought itd be like $10, most places want around 30, with that, ill buy my own. tq different on spacers and lugs for wheels? or are they all same? are they like 70?
Old Jun 21, 2007 | 01:22 PM
dutchboy350Z
Finally some go
I torqued my project kics to 85 lbs. 70 is definitely way too low. I torque my wheel nuts to 90 lbs.
Old Jun 21, 2007 | 01:28 PM
erickim080387
so, 85 for spacers and 90 for lugs? cool. i have rays lugs if its any different.. cuz it makes a squeaking noise whenever i loosen the rays lugs. thanks for the ultra fast response by the way. by the way, ill post some pics next monday or so, taking pics on sunday at a local meet. thakns for all your help guys!
