Need help deciding what rear tire size?? 285/40 or 285/35
Old Jun 24, 2007 | 04:41 AM
original786's Avatar
original786
Default Need help deciding what rear tire size?? 285/40 or 285/35
I have a set up (current) on my bronze nismos
front : 245-40-18
Rear: 275-40-18
One of my rear is gone and the second one is about to be gone.
so need to replace my rears ones now!!
so should i do go with the 275-40-18 again!!
or should i go with 285-40-18 (too big or not ???) or what about 285-35-18?? please help
i know the recommended size for nismo is 245/40 and 275/40 combo
since the rear is 9.5, i wonder if i can go with a 285/40 or 285/35??
Old Jun 24, 2007 | 05:15 AM
mik350z's Avatar
mik350z
And in order that you love 285? Fodder that with 275 you have sufficient gum.
Old Jun 24, 2007 | 05:22 AM
original786
lol say what???
Old Jun 24, 2007 | 05:32 AM
mik350z's Avatar
mik350z
excuse for my bad english .i think 275/40/18 is a good wheel to 350z.
Old Jun 24, 2007 | 05:33 AM
mik350z's Avatar
mik350z
i used in my 350z 235/35/19 front and 255/35/19
Old Jun 24, 2007 | 05:46 AM
original786
so i shouldnt go with the 285, and stick with 275-40?
Old Jun 24, 2007 | 05:47 AM
NY 350Z's Avatar
NY 350Z
I had 285/35s on my 18x9.5.
Old Jun 24, 2007 | 06:02 AM
NA&CH's Avatar
NA&CH
you have FI correct? Go with the 285...What tires?
Chris
Old Jun 24, 2007 | 06:12 AM
original786
yes i have an APS ST
so go with the 285 -40?
or 285-35???
Old Jun 24, 2007 | 06:14 AM
The rear tires are only 3.50 mm taller than the front. I do not like this set-up with VDC.
Old Jun 24, 2007 | 06:20 AM
masterj26's Avatar
masterj26
I ran that setup with absolutely no problems with VDC. OP I would go with 285/35
Old Jun 24, 2007 | 06:28 AM
original786
so if i go with the 285-35-40 in the rear
then my setup would look like
275-40-18 front
285-35-18 rear
will that balance out????
Old Jun 24, 2007 | 07:12 AM
masterj26's Avatar
masterj26
275-40-18 front
285-35-18 rear
I ran:
f: 245/40/18
r: 285/35/18
Old Jun 24, 2007 | 07:21 AM
syk69's Avatar
syk69
i'm running that setup of 245/40/18 with 285/35/18 and have no problems.
Old Jun 24, 2007 | 08:16 AM
Zridder19's Avatar
Zridder19
+1 same here no problems and looks good.
Old Jun 24, 2007 | 08:51 AM
Korki Buchek's Avatar
Korki Buchek
Do not run 275/40 front and 285/35 rear. Your VDC will flip out and kill you in your sleep.
Old Jun 24, 2007 | 09:51 AM
original786
i dont have vdc, i have tcp or is it tpc so does it matter
Old Jun 24, 2007 | 01:12 PM
mthreat's Avatar
mthreat
285/35 are less likely to rub the fender than 285/40 (since the diameter is smaller).
I put 275/40's in mine and I had rubbing issues (only under high-G turns under acceleration). Most people didn't have these issues with the same size tires, but most people don't drive like I do (on the track, mostly). I ended up rolling the inside fender lip, solving the problem completely, but some folks don't want to mess with that. My wheel offset was probably a factor as well.. I probably should have gotten 5mm higher offset.
Old Jun 24, 2007 | 01:38 PM
original786
so im back to the same question should i go 285/40 or 285/34
and will this effect my tpc
Old Jun 24, 2007 | 01:55 PM
masterj26's Avatar
masterj26
what tires are you planning on running in the front is the question. 285/35 is fine in the rear with 245/40 in the front.
