OFFSET and Suspension question
Old Jun 29, 2007 | 07:52 AM
mondi's Avatar
mondi
Default OFFSET and Suspension question
i bought a set of ruff racing 278s black with chrome lip (245/35/19front and 275/30/19 rear) with a 35mm offset all around
how much mm spacers do i need...and how much should i lower the car...recomenadtions
im not sure...car looks good but i think wud look better lower and tires stickin out a little more...thanks
Old Jun 29, 2007 | 08:07 AM
redlude97's Avatar
redlude97
we need wheel widths and need to know if you are willing to roll your fenders to answer that correctly
Old Jun 29, 2007 | 08:40 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Bad offsets IMO, you shouldnt have bought them.
I'll assume its the 9.5/10.5" Id do 10-15mm, with a drop you should roll your fenders for clearance. 10.5" +22 on my friends stock Z rubbed on stock suspension. Also the 275/30 overall diameter is SMALL, it will make the wheel gap in the rear very pronounced
Old Jun 29, 2007 | 10:30 AM
1nate7's Avatar
1nate7
If it's not too late, get the +20 offsets and a 275/35 in the rear.
I think those are 8.5/9.5 widths, so I would run a 20mm spacer. I like the drop of the Tanabe GF210. If you are stuck with a 30 series sidewall in the rear you will need a pretty good drop to close up the gap like Alberto mentioned.
