Tire sizing for 18x9.5 rims all around
Originally Posted by Tubbs
Running any kind of stagger defeats the purpose of having same sized rims. OP... just get 265/35/18's. If you want wider in the future, go for it. For now... just BUY some damn tires. Summer is almost over.
Originally Posted by redlude97
Hmm... aren't the stock 18's 18x8 front and rear? They stagger them 20mm. A 9.5" wheel is the perfect size for a 265 or 275, so why woulnd't you want to stagger them? Running the same size all around IMO is a worse option, since you mess up the height stagger and increase your rear wheel gap by quite a bit. It also can mess up the VDC if you have it.
if you want to stagger, you should have different wheels to begin with. And no, factory the wheels are staggered. Running the same size all around is absolutely, totally a good thing. Makes the car more neutral.
Originally Posted by TimeAttkZ
I would run 35 profile tires if I were in your shoes.
265/35/18 front 275/35/18 rear
But most of the tuner Z's, like the Amuse Z run 265/35/18 all around.
The circumference of the P245/45 x 18 original tire is 83.8210 inches
The circumference of the P265/35 x 18 aftermarket tire is 79.4921 inches
I've been really trying to find answer for this but I couldnt..
Originally Posted by Marino Z
could you kindly explain why running same size all around is worse option?
If you want same size all around, I'd try to split the difference between the stock front and rear diameter, like a 265/40. I still think a 255/40 and 275/40 combo is the way to go, but it's your choice.
Wrong, the factory 03-05 18's are ALL 18x8, and guess which sizes they run on them? 225/45/18 and 245/45/18. Running the same is all around is not totally a good thing, that is totally dependant on your particular setup. What about the case when your car already is setup for oversteer on staggered tires, and then you add equal width tires all around? Then it will oversteer too much. Everything is not black and white
ya... been running a square set up for a year thanks. works great. and these are the stock sizes for my 350
18x8 with a 30mm offset - Front
18x8.5 with a 33mm offset - Rear
Originally Posted by 1nate7
He did. It can mess up VDC (if you have it) and unless you are slammed you will have more wheel gap, especially in the rear if you run a undersized diameter. It can also get you into a oversteer situation if you are not careful. I run same size tires all around on the track but see no advantage for street use other than being able to rotate tires.
no it won't.
it won't?
That might rub in the front. What suspension are you on and what is your camber in the front? I'd probably run 255/40 front, 275/40 rear.
